Understanding Integration with PeopleSoft Order Management
You can use the Order Management to Project Costing Application Engine process (PC_OM_TO_PC) to integrate orders that originate in Order Management to Project Costing. These actions occur to integrate orders between PeopleSoft Order Management and PeopleSoft Project Costing:
  1. The Order Management to Project Costing process uses the Order Schedule Line table (ORD_SCHEDULE) to determine which transactions have a PC Distribution Status field value of N (not distributed).
  2. The Order Management to Project Costing process pulls these rows into PeopleSoft Project Costing.
    Orders appear as transactions with the analysis type that is specified in the Order Management field (PC_AN_TYPE_OM) on the Installation Options - Project Costing Integration page. The Order Management field delivered default value is ORD.
If you set up the appropriate exchange rates, transaction amounts that are not in your business unit currency are converted during the integration process.
See also, PeopleTools: PeopleSoft Process Scheduler
