Understanding the Projects WorkCenter - Reports and Processes
This page shot provides an example of how the Projects WorkCenter – Reports/Processes section can be set up.
This example illustrates the fields and controls on the Projects WorkCenter - Reports and Processes pagelet.
Projects WorkCenter - Reports/Processes page
The Reports/Processes pagelet provides access to system defined reports and processes for which a user has access.
System administrators used the Enterprise Components: Configuring Pagelets to set up the WorkCenter Reports/Processes pagelet for end users. End users use theApplication Fundamentals: Define User “Reports” Links – Reports/Processes Pagelet Personalization Page to personalize the Reports/Processes pagelet for personal use.
