Viewing Project Prompt Tables in Time and Labor
These tables in PeopleSoft Time and Labor are populated by integration with PeopleSoft Project Costing:
  • PC Business Unit (BUS_UNIT_TBL_PC)
  • Operational Projects (PROJECT)
  • Project Activities (PROJ_ACTIVITY)
  • Project Resource Type (PROJ_RES_TYPE)
  • Project Resource Category (PROJ_CATG_TBL)
  • Project Resource SubCategory (PROJ_SUBCAT_TBL)
  • Project Team Member (PROJECT_TEAM)
You can view, but not modify, these tables in PeopleSoft Time and Labor. The PeopleSoft Time and Labor system receives the units of measure table and tableset control tables that contain SetID synchronization from PeopleSoft Project Costing.
The system uses application messaging to synchronize prompt tables between the Financials and HCM databases.
