The Billing Interface Process
Run the Billing Interface process in PeopleSoft Billing to create the temporary bills that you can work on in the billing worksheet. The billing worksheet is a temporary work area in which you can review and adjust billing lines from the Billing Interface process before you create actual bills.
After making adjustments, use the Billing Worksheet component to approve or delete temporary bills.
Instructions about running the Billing Interface process are in the PeopleSoft Billing.
