Overall Installation Options
Use the pages in the Installation Options component (INSTALLATION) to configure the installation information and to indicate how you want to use certain cross-application features. Use this component to:
  • Determine the alternate characters that the system uses for a specific language code.
  • Set specific document management control options that enable the embedded document management system and specify system-level configurations.
  • Enable the use of entry events in PeopleSoft General Ledger, PeopleSoft Payables, PeopleSoft Purchasing, and PeopleSoft Receivables.
You can find instructions for defining overall installation options in the PeopleSoft Applications Fundamentals.
