System Preparation
PeopleSoft Proposal Management integrates with PeopleSoft Contracts, PeopleSoft Project Costing, and PeopleSoft General Ledger to enable bill processing. Before you can perform the billing activities associated with expenditures, you need to set up the billing control tables used by the various applications.
PeopleSoft applications rely on tables to store not only business transactions, but also the structure and processing rules that drive the system. Before you can run the processes to generate invoices, you need to establish the structure that tells the system how you want those processes to work.
Before you run the billing processes or manage billing for your awards, you must prepare your PeopleSoft system accordingly.
Make sure you complete these steps before you initiate the billing processes:
| Step | Navigation |
Set installation options for PeopleSoft Billing. |
Select |
Define a PeopleSoft Billing business unit. |
Select |
Define a distribution code for contract asset. |
Select |
Create a proposal and generate the contract. |
Select Click the Generate button on the Maintain Proposal page. |
Change the status on the contract to Active. |
Select |
Change the status on the billing plan to Ready. |
Select Click the Billing Plans link. Then click the Plan ID link. |
Create billable rows in PeopleSoft Project Costing (use either method):
Note: The methods for creating billable rows described are for rate-based billing only. |
Select Then select the feeder system from which you want to retrieve information. OR Select |
