Setting Up Procurement Card Installation Options
This section lists the page used to set up your procurement card installation options.
Before you can use the procurement card functionality, you must first set up your procurement card installation options. These options determine procurement card controls that are used throughout the procurement card life cycle.
Page Used to Set Up Procurement Card Installation Options
Installation Options - Purchasing Page
INSTALLATION_PO
Define general purchasing controls, such as autonumbering parameters, maximum quantities for quantity price breaks, and the maximum number of rows that are to appear in scroll areas; define requisition loader parameters, such as maximum lines loaded; and define procurement card controls, such as the number of digits that are to appear for a procurement card.
