Using the Procurement WorkCenter in Fluid
Use the Procurement WorkCenter page to access My Work, My Approvals, My Insights, Links, Queries, and Reports/Processes pagelets using the PeopleSoft Fluid User Interface.
The Fluid Procurement WorkCenter is delivered with sample data. It is the responsibility of the system administrator from your organization to design and create links so that users can access and view specific links, pages, and pagelets.
You can activate the pagelets on the Configuring Pagelets page.
Select Enterprise Components > WorkCenter/Dashboard > Configure Pagelets
Enter BUYER as the Configuration ID for fluid Procurement Workcenter.
For more details, see Enterprise Components: Configuring Pagelets.
This topic discusses the pagelets available in the Fluid Procurement WorkCenter.
