Using the Purchase Order Requisition EIP
This section provides an overview of the Purchase Order Requisition EIP and discusses how to process the Purchase Order Requisition EIP.
Pages Used to Use the Purchase Order Requisition EIP
| Page Name | Definition Name | Usage |
RUN_POC1210 |
Set parameters for running the Purchasing Requisition Loader process. |
Data Collection Setup Page |
BCT_SETUP_FS |
Set the option to keep transaction log history for electronic data collection transactions and to set the default file suffix. |
PeopleSoft Supply Chain Management Integration: Data Def Maint Page |
EO_EIP_CTL_MAINT |
View data detail or correct errors for subscribe messages that contain data rather than transactions |
Understanding the Purchase Order Requisition EIP
The Purchase Order Requisition EIP processes requisition data using an asynchronous service operation from PeopleSoft CRM or external surgical resource software application.
This data is loaded to the PO_REQLOAD_RQST and PO_REQLOAD_CMT staging tables.
Run the Purchasing Requisition Loader process to create requisitions from the staged data.
PeopleSoft delivers the service operations in PeopleSoft Integration Broker with a default status of Inactive. You must activate each service operation before attempting to send or receive data from a third-party source or another PeopleSoft system, such as CRM.
Before you can use the Purchase Order Requisition EIP, you must:
Setup the service operation within PeopleSoft Integration Broker and Enterprise Components:
Use the information in the table below and refer to the setup instructions in the PeopleSoft Supply Chain Management Integration, "Implementing Integrations" topic, Setting Up Service Operations section.
Service Operation Direction and Type Handlers Chunking Available? Integrates With PURCHASE_REQUISITION_LOAD
Inbound
Asynchronous
Purchase Requisition
Load
No
third-party system
Surgical Resource Software application
PURCHASE_REQUISITION_LOAD_CRM
Inbound
Asynchronous
Load
No
PeopleSoft CRM
Use the Data Def Maint page to view service operation data and correct error messages that are picked up in the processing of the service operation.
See the product documentation for PeopleTools: Integration Broker
