Control Procedures
Control procedures are a convenience mechanism that you use to specify an overall testing and control scheme that is executed as process data is collected and analyzed. Each procedure is comprised of a list of control tests (listed in order of execution), and optionally, subgroup milestones indicating a progression for control limit calculations. You associate procedures with inspection characteristics to achieve the desired level of process control, feedback, and alarming.
PeopleSoft provides four predefined control procedures, each with a varying number of tests. You can use these predefined control procedures, modify them, or create a set of procedures:
Control Procedure ID # Description Control Tests
1
Level I
Specification limit violation.
1
Level I
Control limit violation (variance).
1
Level I
Control limit violation (mean).
2
Level II
Level I +.
2
Level II
Trend - 7 pts (mean).
2
Level II
Shift - 2 of 3 pts (mean).
2
Level II
Shift - 4 of 5 pts (mean).
2
Level II
Shift - 8 of 8 pts (mean).
3
Level III
Level II +.
3
Level III
Trend - 7 pts (variance).
3
Level III
Shift - 2 of 3 pts (variance).
3
Level III
Shift - 4 of 5 pts (variance).
3
Level III
Shift - 8 of 8 pts (variance).
4
Level IV
Level III +.
4
Level IV
Mixture - 8 pts (mean).
4
Level IV
Systematic variable - 14 pts (mean).
4
Level IV
Stratification - 15 pts (mean).
4
Level IV
Mixture - 8 pts (variance).
4
Level IV
Systematic variable - 14 pts (variance).
4
Level IV
Stratification - 15 pts (variance).
