Understanding PeopleSoft Quality Integration With Other PeopleSoft Applications
The integration of Quality with Purchasing and Manufacturing enables you to:
Initiate a quality data-entry session.
Transfer to the Quality data-entry component.
Enter quality control data for the session.
View the results and alarm information online for the data that you entered against the session.
Return to the initiating application.
The integration with Inventory enables you to:
Initiate and save a quality data-entry session.
Retrieve and complete the quality sessions at a later date directly using Quality pages that were created by the RMA (Return Material Authorization) process.
View online the results and alarm information from the data that you entered against the session.
