Using SQL
Following are a series of sample SQL statements.
Validation SQL Statements
This sample code shows validation statements:
select
PS_QS_STREAM8.STREAM_ID,
PS_QS_STREAM8.QS_APP_CONTEXT
FROM PS_QS_STREAM8,PS_QS_STREAM_ROOT,PS_QS_APP_DEF
WHERE PS_QS_STREAM8.STREAM_ID >= 164 AND PS_QS_STREAM8.STREAM_ID <= 164
and PS_QS_STREAM8.STREAM_ROOT_ID = PS_QS_STREAM_ROOT.STREAM_ROOT_ID
and PS_QS_APP_DEF.QS_APP_CONTEXT = PS_QS_STREAM_ROOT.QS_APP_CONTEXT
ORDER BY STREAM_ID
select
ORDER BY STREAM_ID
select
STREAM_ID,
CLIM_STS_CD,
CLIM_ID,
STR_SGRP_CNT,
STR_SGRP_SEQ,
CUR_SGRP_SIZE,
CUR_SPEC_VIO_CNT,
CUR_PLOT_VALUE1,
CUR_PLOT_VALUE2,
RUN_MOMENT,
TSWIN_BUFFER1,
TSWIN_BUFFER2
FROM PS_QS_STREAM8
WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
select
BUSINESS_UNIT,
STREAM_ID,
CLIM_ID,
CLIM_STS_CD,
CLIM_UPPER_X,
CLIM_UX_IND,
CLIM_MEAN_X,
CLIM_MX_IND,
CLIM_LOWER_X,
CLIM_LX_IND,
CLIM_UPPER_MRANGE,
CLIM_UMRANGE_IND,
CLIM_MEAN_RANGE,
CLIM_MRANGE_IND,
CLIM_LOWER_MRANGE,
CLIM_LMRANGE_IND,
CLIM_CRE_DTTM,
CLIM_CRE_BY
from PS_QS_CNTL_LIM_HIS
ORDER BY CLIM_ID
select
BUSINESS_UNIT,
SESSN_ID,
STREAM_ID,
SESSN_STREAM_SEQ,
SESSN_SGRP_SEQ,
SESSN_STRM_STS,
SESSN_SGRP_SIZE,
MFDS_DATA_TYPE_CD,
SESSN_ANLZ_READY,
CLIM_ID,
SPEC_ID,
SRSLT_P1,
SRSLT_P1_IND,
SRSLT_P2,
SRSLT_P2_IND,
CLIM_STS_CD,
SPEC_VIO_SW,
QS_ANALYZER_STATUS,
QS_ALARM_CNT,
QS_NVALUES,
QS_VALUEREADING_1,
QS_VALUEREADING_2,
QS_VALUEREADING_3,
QS_VALUEREADING_4,
QS_VALUEREADING_5,
DISPATCH_FLAG,
SESSN_SUBMIT_DTTM,
SRSLT_CRE_DTTM,
QS_ACTION_CNT,
QS_CAUSE_CNT,
QS_COMM_CNT,
OPERATOR,
QS_UAID
from PS_QS_SUBGROUP
ORDER BY SESSN_ID
select
BUSINESS_UNIT,
SESSN_ID,
STREAM_ID,
SAMPLE,
TEST_SEQ,
TEST_ID
from PS_QS_SESSN_TEST8
ORDER BY SESSN_ID
Generic SQL Statements
This sample code shows generic statements:
select
STREAM_ID,
CLIM_STS_CD,
CLIM_ID,
STR_SGRP_CNT,
STR_SGRP_SEQ,
CUR_SGRP_SIZE,
CUR_SPEC_VIO_CNT,
CUR_PLOT_VALUE1,
CUR_PLOT_VALUE2,
RUN_MOMENT,
TSWIN_BUFFER1,
TSWIN_BUFFER2
FROM PS_QS_STREAM8
select * from PS_QS_CNTL_LIM_HIS WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
select PS_QS_SESSN_HDR8.* from PS_QS_SUBGROUP,PS_QS_SESSN_HDR8
AND PS_QS_SESSN_HDR8.SESSN_ID = PS_QS_SUBGROUP.SESSN_ID
select PS_QS_SESSN_TRACE8.* from PS_QS_SUBGROUP,PS_QS_SESSN_TRACE8
WHERE STREAM_ID >= 164 AND STREAM_ID <= 164 AND PS_QS_SESSN_TRACE8.SESSN_ID = PS_⇒
select * from PS_QS_SUBGROUP WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
select * from PS_QS_SESSN_DFCT8 WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
select * from PS_QS_SESSN_TEST8 WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
SQL to Reset Database Tables
This sample code shows statements to reset database tables:
update PS_QS_STREAM8 set
CLIM_STS_CD = "NONE",
CLIM_ID = "NONE",
STR_SGRP_CNT = 0,
STR_SGRP_SEQ = 0,
CUR_SGRP_SIZE = 0,
CUR_SPEC_VIO_CNT = 0,
CUR_PLOT_VALUE1 = 0,
CUR_PLOT_VALUE2 = 0,
RUN_MOMENT = 0,
TSWIN_BUFFER1 = "",
TSWIN_BUFFER2 = ""
delete from PS_QS_SESSN_HDR8 WHERE SESSN_ID in (select SESSN_ID from PS_QS_⇒
SUBGROUP
where STREAM_ID >= 164 AND STREAM_ID <= 164)
delete from PS_QS_SESSN_TRACE8 WHERE SESSN_ID in (select SESSN_ID from PS_QS_⇒
SUBGROUP
delete from PS_QS_SESSN_DFCT8 WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
delete from PS_QS_CNTL_LIM_HIS WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
delete from PS_QS_SESSN_TEST8 WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
delete from PS_QS_SUBGROUP WHERE STREAM_ID >= 164 AND STREAM_ID <= 164
SQL to Retrieve Stream Information
This sample code shows statements to retrieve information:
select
STREAM_ID,
MFDS_ID,
CLIM_STS_CD,
STR_SGRP_CNT,
STR_SGRP_SEQ,
CLIM_ID,
CUR_SGRP_SIZE,
CUR_SPEC_VIO_CNT,
CUR_PLOT_VALUE1,
CUR_PLOT_VALUE2,
RUN_MOMENT,
TSWIN_BUFFER1,
TSWIN_BUFFER2,
SPEC_ID,
SPEC_LSL,
SPEC_LSL_IND,
SPEC_USL,
SPEC_USL_IND,
SPEC_FACTOR1,
SPEC_FACTOR1_IND,
SPEC_FACTOR2,
SPEC_FACTOR2_IND,
MFDS_COLLECT_SW,
MFDS_NAME,
MFDS_SGRP_SIZE,
MFDS_DATA_TYPE_CD,
MFDS_LAL,
MFDS_LAL_IND,
MFDS_UAL,
MFDS_UAL_IND,
MFDS_INC_CD,
MFDS_FORMULA,
CHART_ID,
PROC_ID,
CLIM_UPPER_X,
CLIM_UX_IND,
CLIM_MEAN_X,
CLIM_MX_IND,
CLIM_LOWER_X,
CLIM_LX_IND,
CLIM_UPPER_MRANGE,
CLIM_UMRANGE_IND,
CLIM_MEAN_RANGE,
CLIM_MRANGE_IND,
CLIM_LOWER_MRANGE,
CLIM_LMRANGE_IND
FROM PS_QS_API_STR83_VW
ORDER BY STREAM_ID
