Using Test Statistics
The following table lists the two single sample statistical confidence tests: a mean test and a Stdev test (standard deviation test).
Equation Statistic
gv_7baf_sqsy7e77
The mean test is a t-test that tests the mean of the current sample versus a target mean that you supply. Once the t value is calculated, it is compared to the t statistic (table value), which is determined by the confidence level selected for a one-sided test. The test assumes that the samples are normally distributed.
See References.
gv_7bae_sqsy7e75
The standard deviation test is a chi-square test that tests the standard deviation of the current sample versus a target standard deviation that you supply. Once the chi-square value is calculated, it is compared to the chi-square statistic (table value), which is determined by the confidence level selected for the test. The standard deviation test has a limitation of
gv_7bad_sqsy7e73
= 100.
See References.
