Running the Component Interface Conversion Process
Use the Excel to Component Interface utility to run the component interface. When you build the worksheet template, select the DC_PENDITEM_CI component interface.
The PeopleTools documentation describes how to use the Excel to Component Interface utility in detail.
See the product documentation for PeopleTools: Component Interfaces.
