Using the PeopleSoft Classic Receivables WorkCenter - Links
Use the Receivables WorkCenter - Links pagelet to view the Receivables links. The primary purpose of this pagelet is to minimize the number of clicks to access critical path components and pages. Click any of the links on the pagelet to display the destination page in the transaction area.
The Links pagelet can provide access to internal links and external links.
This example illustrates how the Links pagelet in PeopleSoft Classic Receivables WorkCenter can be set up using preconfigured links:
This example illustrates the fields and controls on the PeopleSoft Classic Receivables WorkCenter - Links pagelet (1 of 2). You can find definitions for the fields and controls later on this page.
This example illustrates the fields and controls on the PeopleSoft Classic Receivables WorkCenter - Links pagelet (2 of 2).
To set up the WorkCenter Links pagelet as a system administrator, see Enterprise Components: Configuring Pagelets.
To use and personalize the WorkCenter Links pagelet as an end user, see Application Fundamentals: Working With and Personalizing the Classic Links Pagelet As an End User.
For more information about setting up query pagelets as a system administrator, see Enterprise Components: Configuring Pagelets.
For more information about setting up query pagelets as an end user, see Application Fundamentals: Working With and Personalizing the Classic Queries Pagelet As an End User.
