Establishing Application Setup Tables for Work Definitions
This topic discusses how to set up work definition tables.
Pages Used to Establish Application Setup Tables for Work Definitions
PeopleSoft Staffing Front Office: Frequency Setup Page
RS_CM_FREQNCY_TBL
Define a frequency ID, its frequency type (such as annual, monthly, weekly, biweekly, bimonthly, daily, or hourly), and its annualization factor (how many frequency periods occur in one year).
Holiday Schedule
RS_CM_HOLIDAY_TBL
Identify the holidays observed by the organization.
PeopleSoft Staffing Front Office: Job Code Definition Page
RS_CM_JOBCODE_TBL
Establish a code for each job that a resource holds in the organization.
Job codes can be alphanumeric.
Setting Up Work Definition Tables
Define each work definition table by completing these steps:
  1. Access the setup table page.
  2. Enter a new or existing code for the work definition.
  3. Enter or update the description and other required fields for the code.
  4. Save the record and click Add to create the next code and definition.
