PeopleSoft Resource Management Reports: A to Z
This table lists the PeopleSoft Resource Management reports and interactive reports, sorted alphanumerically by report ID. The reports are BI Publisher reports, and are designated with a PeopleSoft Process Scheduler run control page ID. The remaining items in the list are interactive reports that you can generate during a business process or from the Interactive Reports folder. Interactive reports are not scheduled through the PeopleSoft Process Scheduler.
Report ID and Report Name Description Navigation Run Control Page
RS_2020TUTR_RPT
Scheduled Utilization
Compare scheduled utilization with optimal capacity for a specified organization unit and period of time. This interactive report supports the business process of managing resources.
See Reviewing Utilization Charts.
Resource Management, and then Interactive Reports, and then Scheduled Utilization Report
Click Generate Report.
Not applicable
RS_2020TUTR_STAT
Scheduled Utilization - Employee Statistics
View the resources in the Scheduled Utilization chart. This interactive report supports the business process of managing resources.
Click Go To Resource List in the Scheduled Utilization chart page.
Not applicable
RS_2030BENCH_RPT
Unassigned Resources
Analyze resources who do not meet the threshold that you define for determining that a worker is assigned. This interactive report provides a chart and lists the unassigned and assigned resources in the organizational units represented by the tree node or detail value that you specify at run time. This interactive report supports the business process of assigning resources to projects.
Resource Management, and then Interactive Reports, and then Unassigned Resources Report
Not applicable
RS_2040WRKRCOM_DTL
Assignments Ending (detail)
View information about a specific resource's specialties and schedule. This interactive report supports the business process of assigning resources to projects.
Select a resource name link on the Assignments Ending (summary) page.
Not applicable
RS_2040WRKRCOM_RPT
Assignments Ending (list)
Analyze resources who might be available on a certain date with certain skills. View a list of resources who have assignments ending within a specified date range. This interactive report supports the business process of assigning resources to projects.
See Staffing Workbench - Manage Utilization Page.
Resource Management, and then Interactive Reports, and then Assignments Ending Report
Not applicable
RS_2045WRKRSCH_RPT
Chart Resource Schedules
Displays a chart of resource schedules so that you can quickly identify scheduled and available time. This interactive report supports the business process of assigning resources to projects.
Resource Management, and then Interactive Reports, and then Chart Resource Schedules Rpt
Not applicable
RS_2090AVST_RPT
Average Staffing Time (chart)
View trends in staffing time by charting the average amount of time it takes to fulfill service orders in a specified period.
Resource Management, and then Interactive Reports, and then Average Staffing Time Report
Not applicable
RS_2090AVST_STATP
Average Staffing Time (detail)
View the breakdown of the average staffing time by service order priority, staffing coordinator, or owning organization.
Click Go To Average Staffing Time per <Priority, Coordinator, or Owning Organization> on the Average Staffing Time chart page.
Not applicable
RS_2100COMP_DTL
Most Requested Competencies & Accomplishments (detail)
Identifies the most requested competencies and accomplishments to assist you in the recruitment of resources who best meet your historical or future needs. View lists containing the most requested competencies and accomplishments in descending order by number of requests. This interactive report supports the business process of managing resources.
Click anywhere in the Most Requested Competencies chart or Most Requested Accomplishments chart.
Not applicable
RS_2100COMP_RPT
Most Requested Competencies & Accomplishments (chart)
View charts containing the most requested competencies and accomplishments. Popularity is determined by the number of times that a particular competency or accomplishment appears on resource requests for a given business unit in a given time period. You can use this information to assist you in the recruitment of resources who best meet your historical needs. This interactive report supports the business process of managing resources.
Resource Management, and then Interactive Reports, and then Most Requested Competency Rpt
Not applicable
SRS2000
Service Order Listing
View a list of service orders by status and priority. This report supports the business process of assigning resources to projects.
Resource Management, and then Reports, and then Service Order Listing Report
Click Run to run the report by using PeopleSoft Process Scheduler.
RS_2000SOLIST_PAR
SRS2015
Assignments Listing Report
View a list of resources currently on assignment. This report supports the business process of assigning resources to projects.
Resource Management, and then Reports, and then Assignment Listing Report
Click Run to run the report using the PeopleSoft Process Scheduler.
RS_2015ASSGNLS_RPT
See the product documentation for PeopleTools: Process Scheduler
