Shared Data Between PeopleSoft HCM and PeopleSoft Resource Management
For the integration between PeopleSoft HCM and PeopleSoft Resource Management, HCM is the publisher of changes to data, and Resource Management is the subscriber. This diagram illustrates the data-sharing process:
To use PeopleSoft application messages, you must activate the Publication and Subscription services on the PeopleSoft Resource Management and PeopleSoft HCM application servers.
If you integrate PeopleSoft Resource Management with PeopleSoft HCM, you must also activate the data synchronization application messages.
If you use PeopleSoft Resource Management without an integrated HCM, the data synchronization application messages should not be activated.
