Understanding the Resource Management WorkCenter and Dashboard
The Resource WorkCenter is a central navigational component that is designed for the end user. The goal of the WorkCenter is to help an end user become more efficient by accessing frequently used pages and pagelets, and by keeping multiple pages open while performing daily tasks.
The Resource WorkCenter is delivered with sample data. It is the responsibility of the system administrator from your organization to design and create links so that users can view and access specific links, pages, and pagelets.
For information about setting up PeopleTools options for the WorkCenter, see PeopleTools: Global Technology
PeopleSoft Classic WorkCenter Tabs and Pagelets
There are common pagelets within a WorkCenter:
Main tab:
My Work
Links
Reports/Queries:
Queries
Reports and Processes
WorkCenters also provide a Welcome pane, which appears to the right of the left pane. A Welcome page explains some of the basic icons that are used throughout the WorkCenter. If a system administrator or an end user (if given access rights) selects the Starting Page check box on the Configure Pagelets component for My Work, Links, Queries, or Reports/Processes, then the option selected replaces the Welcome page in this pane.
