Required or Ideal Response Designation
You can designate that a response is required for a bid factor. If required, the bidder must enter a response for the specified bid factor before successfully posting a bid.
You can also designate that the ideal or best response is required for a bid factor. The bidder's response must match the specified best or ideal response for the bid to be considered for award.
