Using the Contract/Sourcing WorkCenter - Dashboard
You can access the Contract/Sourcing Dashboard from within your Contract/Sourcing WorkCenter. When you first click the Contract/Sourcing WorkCenter Dashboard link, the delivered pagelets appear by default. You can click the refresh button for each pagelet to view the data.
You can configure and personalize the Dashboard pagelet presentation (for example, presenting the pagelets side-by-side) by using Personalize Content/Layout links located in the top right corner of your working zone.
Dashboards can display pivot grids that can also be displayed on a users’ Home page. Pivots grids are based on PSQueries and can display the results in a grid format, a chart format, or both. You use the Pivot Grid Wizard (Reporting Tools, Pivot Grid, Pivot Grid Wizard) to design how the page is displayed to the user.
Pivot Grids can be added as pagelets (on a user’s Home page) and to the Queries tab in a WorkCenter.
This example illustrates the fields and controls on the Contract/Sourcing Workcenter Dashboard.
Related Topics
