Using the Data Migration Workbench for PeopleSoft Supplier Contract Management
Application Data Sets (ADS) can be used with PeopleSoft Supplier Contract Management for the purpose of moving data between development environments, test environments, and ultimately to a production environment.
This table lists the delivers ADS definitions (delivered in Data Set Designer) to support the migration of PeopleSoft Supplier Contract Management setup data.
Delivered ADS to Support PeopleSoft Supplier Contract Management Setup Dependencies Application Data Set (ADS) Usage
Document Formats and Options - CS_DOC_FORMAT
None
This data set includes the records that define the default word template used to create and preview clause and section content, and paragraph styles
Note: The data in Document Templates and Styles must be manually updated on the target database before replicating data from this data set.
Document Configurator Types - CS_DOCUMENT_CONFIG_TYPE
None
This data set includes the records that define requirements used in document configurators.
Libraries - CS_LIBRARIES
None
This data set includes the records that define clause libraries.
Approval Types - CS_APPROVAL_TYPE
None
This data set includes the records that define approval types that indicate risk levels and approval settings by role.
Note: If a role does not exist in target database, there could be validation errors. You should copy the role definitions before you copy approval types.
Classes - CS_CLASSES
Approval Types
Note: Approver types are optional for a class. With this relation, the Data Migration Workbench prompts you whether the approver type should be included in the migration.
This data set includes the records that define classes and maps to approval types.
User Defined Fields - CS_USER_DEFINED_FIELDS
Binds
Note: With this relation, the Data Migration Workbench prompts you whether to insert data for any bind used in user defined fields.
This data set includes the records that define user defined fields for character, date, integer, and decimal data types. These fields can be tied to bind variables and can be used to search for documents.
Wizard Prompt Tables - CS_WIZARD_PROMPTS
None
This data set includes the records that define the prompt tables used by bind definitions.
Binds - CS_BINDS
Note: With this relation, the Data Migration Workbench prompts you whether to include wizard prompt tables used in the data content for bind variables.
This data set includes the records that define bind variables used by clauses, sections, rules, and supplier contract documents.
Bind Mappings - CS_BIND_MAPPINGS
Binds
Note: With this relation, the Data Migration Workbench prompts you whether to include bind variables used in the data content.
This data set includes the records that define the mappings between transaction type bind variables.
My Document Preferences:
  • CS_DOCPREF_COLLABORATORS
  • CS_DOCPREF_ROLEACCESS
Operator Definitions and Roles
This data set includes the records that define default internal collaborators and role level view access for documents. The two records that contain the data to be transported are not related and therefore two data sets are needed.
If you need to copy data for collaborators and role access, then the project must include both data sets in Data Migration Workbench.
If you do not need to copy data for collaborators and role access, then include the one that has the data change. For example, if you only want to make changes to default collaborators, then copy only CS_DOCPREF_COLLABORATORS.
User Preferences - CS_USER_PREFERENCES
This data set included the records that define document and administrator privileges for authored documents.
Note: If a user profile does not exist in target database, there could be validation errors. You should copy the user profiles before you copy user preferences.
Rules - CS_RULES
Binds, Clauses and Sections
This data set includes the records that define the rules used by clauses, sections, and document configurators.
Clauses and Sections - CS_CLAUSES_SECTIONS
Binds, Rules, and Clauses
With the Approval Type relation, the Data Migration Workbench includes the approval types used for clauses.
With the Binds relation, the Data Migration Workbench includes the bind variables used for clauses, sections, or both.
With the Classes relation, the Data Migration Workbench includes the classes used for clauses.
With the Clauses relation, the Data Migration Workbench prompts you whether to include the clauses and sections used as dependents.
With the Alternate Clause relation, the Data Migration Workbench prompts you whether to include the clauses that are used as alternate clauses.
With the Libraries relation, the Data Migration Workbench prompts you whether to include the clauses that are used for clauses.
With the Roles relation, the Data Migration Workbench prompts you whether to include rules that are used in alternate clauses.
This data set includes the records that define:
  • The clauses used in sections and document configurators. All data in the records added to the data set definition are copied, such as clause header and details, alternate clauses, dependent clauses, and bind usage.
  • The sections used in document configurators. All data in the records added to data set definition are copied, such as clause header and details, dependent clauses, dependent sections, rules, and bind usage.
Clause Groups - CS_GROUPS
Clauses
With the Classes relation, the Data Migration Workbench inserts bind data used for User Defined Fields.
This data set includes the records that define groups to organize and categorize clauses.
Contract Agreements - CS_CONTRACT_AGREEMENT
Clauses and Operator Definitions
This data set includes the records that define the contract agreement codes used in purchasing contracts and can be used as a bind for authored documents.
Question Groups - CS_QUESTION_GROUPS
Binds
This data set includes the records that define questions groups and navigational features.
Wizards -CS_WIZARDS
Question Groups
This data set includes the records that define wizards that have predefined question groups, and are used in a document configurator.
Document Configurators - CS_DOC_CONFIGURATORS
Rules, Clauses and Sections
This data set includes the records that define configurators or templates that use clauses, sections, and rules to create source documents.
Document Configurator Groups - CS_DOC_CONFIG_GROUP
This data set includes the records that define document configurator groups based on certain contractual requirements or organizational needs.
Document Types - CS_DOC_TYPE
Document Configurators and User Defined Fields.
This data set includes the records that define document types that can be used to categorize and configure authored documents by source transactions.
For more information about the details of each data set, see Understanding PeopleSoft Supplier Contract Management Setup
For more information about application data sets and data set implementation, see:
