Using Document-Related Pagelets
Supplier Contract Management provides employee- and supplier-facing pagelets that collaborators, document administrators, and suppliers can use to view documents. You can select to display the pagelets using the Content link on the Home page. See PeopleSoft Financials, ESA, ALM, and SCM Portal Packs: PeopleSoft Financials, ESA, ALM, and SCM Portal Packs Overview.
