Common Elements Used in Supply Chain Management Integration
Field or Control Description
As of Date
The first date for which a report or process includes data.
BU or Business Unit
An identification code that represents a high-level organization of business information. You can use a business unit to define regional or departmental units within a larger organization.
Description
Freeflow text up to 256 characters.
Short Description
Freeflow text up to 15 characters.
Effective Date
Date which a table row becomes effective; the date that an action begins. For example, if you want to close a ledger on June 30, the effective date for the ledger closing would be July 1. This date also determines when you can view and change the information. Pages and batch processes that use the information use the current row.
See PeopleTools: Applications User's Guide
Language or Language Code
The language of the field labels and report headings of reports to print. The filed values appear as you enter them. Language also refers to the language spoken by an employee, applicant, or non-employee.
Process Frequency
Designates the appropriate frequency to process:
Once: executes the request the next time the batch process runs. After the batch process runs, the process frequency is automatically set to Don't Run.
Always Executes: executes the request every time the batch process runs.
Don't Run: Ignores the request when the batch process runs.
Process Monitor
View the status of submitted process requests.
See PeopleTools: Process Scheduler
Report ID
The report identifier.
Report Manager
View report content, check the status of a report, and see detailed messages.
Run Control ID
A request identification that represents a set of selection criteria for a report or process.
Run
Specify the location where a process or job runs and the process output format.
Status
Check the progress of a report or process. A valid status is Posted, Not Posted, Generated, Processing, or Scheduled.
User ID
The system identifier for the individual who generates a transactions.
Instance or Prcs Instance
The number that represents where the request is in the queue.
