Identifying Taxware Plug-in Locations
By default, the PeopleSoft system searches for the interlink plug-in in the interface drivers directory, as described in the following table:
| Location | Mode |
For two-tier testing on Windows. |
For Windows application server and PeopleSoft Process Scheduler server. |
For UNIX application server and PeopleSoft Process Scheduler server. |
These directories also contain the XML script files that describe the interlink plug-in structure which were used to create the delivered business interlink objects in the PeopleSoft system. The XML script files have the same name as the Windows DLL plug-in, except that the .XML extension is used instead of the .DLL extension.
When you purchase the
Taxware software, Taxware provides the interlink plug-in that you
must place in these directories. The copy under the Windows directory <PS_HOME>\bin\client\winx86\InterfaceDrivers is not used in production. The PeopleSoft Process Scheduler server
and the application server use the plug-in copy in <PS_HOME>\bin\server\winx86\InterfaceDrivers on Windows, or <PS_HOME>/bin/interfacedrivers on UNIX.
Application Server Configurations
The application server configuration file has the following entry, which you can use to change the plug-in default location:
[PSTOOLS]
; General settings for PSTOOLS
;Uncomment this to specify an alternate directory to search for Interface Drivers.
;Business Interlink Driver Directory=
Process Scheduler Configurations
The PeopleSoft Process Scheduler configuration file contains the following entry, which you can use to change the plug-in default location:
;Uncomment to specify an alternate directory to search for Interface Drivers.
