Identifying Vertex Q Series DLLs and Shared Library Locations
Vertex-supplied DLLs or shared libraries can be placed in the following locations:
Refer to the Vertex documentation for more information.
Windows NT
Typically, the Vertex DLLs should be placed in the same directory as the PeopleSoft main executable file:
| Location | Mode |
For two-tier testing on Windows. |
For Windows application server and PeopleSoft Process Scheduler server. |
UNIX
shared libraries should be placed in the same directory with the other
PeopleSoft libraries. This directory is <PS_HOME>/bin. It is usually one of the directories pointed to by the LIBPATH environment
variable set up in the psconfig.sh UNIX
shell script.
If the system cannot find either the plug-in DLL/shared library or Vertex DLLs/shared libraries, an interlink connectivity error appears.
