Manufacturing Picking Extract File Format
The system generates the manufacturing extract file at the same time that the system initiates the pick plan.
For manufacturing extract data, the control flags reflect the requirements for the component ID, not the item ID.
Picking Plan Extract File Field Name Format
Business Unit*
Char 10
Extract Source Flag*
Char 1
Pick Batch ID
Nbr 10
Pick List Line Number
Nbr 5
Sequence Number
Nbr 2
Pick Mode Flag*
Char 1
Production Area
Char 10
Production ID
Char 10
Production Type*
Char 2
Issue Method*
Char 4
Item ID*
Char 40
Item Description 30
Char 30
Item Configuration Code
Char 50
Original Component ID
Char 40
Component ID
Char 40
Component Description 30
Char 30
Component Configuration Code
Char 50
Operation Sequence
Nbr 4
Quantity Code*
Char 3
Required Date*
Char 8
Required Time*
Char 6
Work Center Code
Char 10
Work Center Description
Char 30
To Container ID
Char 10
To Storage Area
Char 5
To Storage Level 1
Char 4
To Storage Level 2
Char 4
To Storage Level 3
Char 4
To Storage Level 4
Char 4
Container ID
Char 10
Storage Area
Char 5
Storage Level 1
Char 4
Storage Level 2
Char 4
Storage Level 3
Char 4
Storage Level 4
Char 4
ASRS ID
Nbr 15
Order/Pick Quantity in Standard UOM
Nbr 11.4
Order/Pick Quantity in Order/Pick UOM
Nbr 11.4
Reserved Quantity in Standard UOM
Nbr 11.4
Reserved Quantity in Location UOM
Nbr 11.4
Available Quantity in Standard UOM
Nbr 11.4
Available Quantity in Location UOM
Nbr 11.4
Standard UOM
Char 3
Order/Pick UOM
Char 3
Location UOM
Char 3
Order/Pick UOM Conversion Rate
Nbr 7.8
Location UOM Conversion Rate
Nbr 7.8
Lot ID
Char 15
Lot Expiration Date
Char 8
Lot Availability Date
Char 8
Serial ID
Char 35
Lot Control Flag
Char 1
Serial Control Flag
Char 1
Staged Date Control Flag
Char 1
Actual Cost Control Flag
Char 1
Maintain Production ID Flag
Char 1
Non Own Flag
Char 1
Original or Reprint Flag*
Char 1
Substitute Flag
Char 1
Date / Time Stamp*
Char 14
Field-Specific Notes
See the field-specific-information that follows.
Business Unit
The Business Unit field permits possible larger sizes to accommodate customer revisions. In general, field sizes should match that within the PeopleSoft COBOL programs. Online pages use the sizes defined within PeopleSoft Data Designer.
Extract Source Flag
0 = Inventory Pick Plan
1 = Manufacturing Pick Plan
Pick Mode Flag
0 = Push
1 = Pull
Production Type
PR = Production
RW = Rework
TD = Teardown
Issue Method
ISS = Issue
REPL = Replenish
KIT = Kit
Item ID
This field permits possible larger sizes to accommodate customer revisions. In general, field sizes should match that within the PeopleSoft COBOL programs. Online pages use the sizes defined within PeopleSoft Data Designer.
Quantity Code
ORD = per Order
ASY = per Assembly
Required Date
The format is CCYYMMDD.
Required Time
The format is HHMMSS.
A reprinted extract reflects the current data values in the database. If any pick transactions have been applied between the original and reprinted extract, the data content may differ.
0 = Original
1 = Reprint
Date / Time Stamp
The format is CCYYMMDDHHMMSS.
