Production Completion Label
The label extract file record definitions define the format for the label extract file.
Production Completion Label Field Name Format Desc./Com.
Label Format ID
Char 30
N/A
Business Unit
Char 10
See note.
Production ID
Char 10
N/A
Production Area
Char 10
N/A
Item ID
Char 40
See note.
Item Description 30
Char 30
N/A
Configuration Code
Char 50
N/A
Revision
Char 4
N/A
Production Type
Char 2
N/A
Lot Control Flag
Char 1
N/A
Serial Control Flag
Char 1
N/A
Staged Date Flag
Char 1
N/A
Actual Cost Flag
Char 1
N/A
Lot ID
Char 15
N/A
Standard Unit of Measure
Char 3
N/A
Standard Pack Quantity
Nbr 11.4
N/A
Std Pack Unit of Measure
Char 3
N/A
Quantity in Std Pack UOM
Nbr 11.4
N/A
Date
Date
CCYYMMDD
Op Sequence
Number 4.0
N/A
Output Type
Char 2
N/A
Certain fields allow for possible larger sizes to accommodate customer revisions. In general, field sizes should match that within the PeopleSoft COBOL programs. Online pages use the sizes as defined within PeopleSoft Application Designer. A size mismatch between the file and the definition may result in an error when data is retrieved through the flat file.
