Setting Up Taxware on a UNIX Platform
You must set up several
environment variables with the location of the Taxware database files.
Taxware provides a script called ENVARS that contains
all the variables that need to be defined. In ENVARS, provide
values for these variables, and then run the ENVARS script when starting
the application server and PeopleSoft Process Scheduler. A typical
place to run the ENVARS script is in psconfig.sh.
Taxware opens the database files in read/write mode. Consequently, you may encounter problems with permissions.
