Capacity Plan Workbench - Display Row Types Page
Use the Capacity Plan Workbench - Display Row Types page (PL_WB_ROWTYPE_SEC) to modify the workbench row types that appear and the order in which they appear.
Changes that you make to row type preferences on this page override those preferences that are defined on the Define Display Template page. However, the system does not save these changes to the Define Display Template page. Modifications that you make on this page are temporary; the system deletes these changes when you navigate away from the workbench.
Navigation:
Click the Display Row Types button on the Capacity Workbench Search page.
You can access the Display Row Types page on all of the workbench and review pages where row types are used, including the Material Plan Workbench, Review Material Summary Plan, Buyer Workbench, and Review Buyer Purchases pages.
| Field or Control | Description |
Sort Order Number |
Define the order in which the row types appear on the workbench. |
Display Row Type |
Select to include the corresponding row type on the workbench display. |
Include in Chart |
Select to include the row type in generated graphic representations. |
Select All Row Types |
Click to select all row types for display on the workbench. |
Clear All Row Types |
Click to exclude all row types for display on the workbench. |
Related Topics
