Defining Attributes in PeopleSoft Supply Chain Management
Before using PeopleSoft Supply Planning, you must define attributes in other PeopleSoft applications within the PeopleSoft Supply Chain Management application suite. This topic details the key setup pages and components and discusses how to:
  • Set up work center planning attributes.
  • Define and review manufacturing BOMs.
  • Define manufacturing routings.
  • Define item attributes at the business unit level.
  • Define planner codes.
  • Establish closure calendars.
  • Set up stocking periods.
  • Set up demand priority families.
  • Define transfer attributes.
  • Define purchasing attributes.
  • Define forecast sets.
  • Define forecast product information.
  • Create item forecasts.
  • Apply Security for Business Units and Planning Instances.
