Using the Capacity Workbench
You use capacity plans to manage resources and determine the amount of capacity that is required to produce products in the future. With the capacity plan, you can view capacity by user-specified buckets and navigate to production details where you can add, delete, or cancel production, reschedule tasks, and change quantities.
This topic provides an overview of the Capacity Workbench and capacity calculations and discusses how to use the Capacity Workbench.
