dashboards-maps Fourth-Party Licenses
4th party dependencies distributed by PeopleSoft for dashboards-maps:
------------------------------- Top-level license --------------------------
------------------------------- Copyright notices --------------------------
Copyright OpenSearch Contributors
---------------------------- Fourth-party information ----------------------
== NAME OF DEPENDENCY 1
human-signals-1.1.1
== License Type
Apache 2.0 License
== Copyright Notices
Copyright 2019 ehmicky <ehmicky@gmail.com>
--------------------------------(separator)---------------------------------
== NAME OF DEPENDENCY 2
blob-util
aws-sign2
rxjs
forever-agent
@cypress/request
caseless
tunnel-agent
== License Type
Apache 2.0 License
Grant of Copyright License. Subject to the terms and conditions of this License, each Contributor hereby grants to You a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable copyright license to reproduce, prepare Derivative Works of, publicly display, publicly perform, sublicense, and distribute the Work and such Derivative Works in Source or Object form.
== NAME OF DEPENDENCY 3
Uuid
astral-regex
strip-final-newline
pify
cachedir
onetime
common-tags
pretty-bytes
cli-truncate
path-is-absolute
ospath
string-width
cli-cursor
is-path-inside
form-data
shebang-regex
slice-ansi
execa
is-fullwidth-code-point
cypress
executable
clean-stack
indent-string
balanced-match
log-symbols
aggregate-error
ansi-regex
has-flag
figures
through
restore-cursor
is-typedarray
shebang-command
eventemitter2
global-dirs
wrap-ansi
npm-run-path
p-map
is-installed-globally
minimist
dashdash
ansi-styles
mimic-fn
ms
isstream
assert-plus
colorette
escape-string-regexp
untildify
proxy-from-env
punycode
type-fest
combined-stream
throttleit
supports-color
strip-ansi
get-stream
path-key
ansi-escapes
performance-now
concat-map
log-update
is-unicode-supported
is-stream
delayed-stream
emoji-regex
chalk
csscolorparser
gl-matrix
murmurhash-js
== License Type
MIT License
None included
== NAME OF DEPENDENCY 4
concat-stream - Copyright (c) 2013 Max Ogden
has - Copyright (c) 2016 Jordan Harband
Copyright (c) 2022 Inspect JS
has-symbols - Copyright (c) 2016 Jordan Harband
has-proto - Copyright (c) 2016 Jordan Harband
Call-bind - Copyright (c) 2020 Jordan Harband
Get-intrinsic - Copyright (c) 2020 Jordan Harband
Side-channel - Copyright (c) 2020 Jordan Harband
sshpk - Copyright Joyent, Inc. All rights reserved
getpass - Copyright Joyent, Inc. All rights reserved
http-signature - Copyright Joyent, Inc. All rights reserved
cross-spawn - Copyright (c) 2018 Made With MOXY Lda hello@moxy.studio
mime-types - Copyright (c) 2014 Jonathan Ong me@jongleberry.com Copyright (c) 2015 Douglas Christopher Wilson doug@somethingdoug.com
isarray
Hat - Copyright (c) 2013 James Halliday
Copyright (c) 2010, Linden Research, Inc
Copyright (c) 2012, Joshua Bell
Object-inspect - Copyright (c) 2013 James Halliday
Traverse - Copyright (c) 2013 James Halliday
Typedarray - Copyright (c) 2013 James Halliday
Async - Copyright (c) 2010-2018 Caolan McMahon
safer-buffer - Copyright (c) 2018 Nikita Skovoroda <chalkerx@gmail.com>
listr2 - Copyright (c) Cenk Kilic <cenk@kilic.dev> (https://srcs.kilic.dev), Sam Verschueren <sam.verschueren@gmail.com> (github.com/SamVerschueren)
install - Copyright (c) 2015 Benjamin Newman <ben@benjamn.com>
asn1 -Copyright 2008 Fair Oaks Labs, Inc.
aws4 - Copyright 2013 Michael Hart (michael.hart.au@gmail.com)
Pend - Copyright (c) 2014 Andrew Kelley
Yauzl - Copyright (c) 2014 Josh Wolfe
Enquirer - Copyright (c) 2016-present, Jon Schlinkert.
Copyright (c) 2014-2017, Jon Schlinkert
Global-prefix - Copyright (c) 2016-present, Jon Schlinkert.
Kind-of - Copyright (c) 2016-present, Jon Schlinkert.
Bluebird - Copyright (c) 2013-2018 Petka Antonov
Lodash - Copyright OpenJS Foundation and other contributors https://openjsf.org/ Copyright and related rights for sample code are waived via CC0. Sample
Asynckit - Copyright (c) 2016 Alex Indigo
safe-buffer - Copyright (c) Feross Aboukhadijeh
fs-extra - Copyright (c) 2011-2017 JP Richardson
Commander - Copyright (c) 2011 TJ Holowaychuk <tj@vision-media.ca>
json-schema - Copyright (c) 2005-2015, The Dojo Foundation
1) Grant of Copyright License. Licensor hereby grants You a world-wide requirements and penalties of the U.S. Copyright Act, 17 U.S.C. § 101 et. This license is Copyright (C) 2003-2004 Lawrence E. Rosen. All rights reserved.
cli-table3 - Copyright (c) 2014 James Talmage <james.talmage@jrtechnical.com>
color-convert - Copyright (c) 2011-2016 Heather Arthur <fayearthur@gmail.com>
mime-db - Copyright (c) 2014 Jonathan Ong me@jongleberry.com Copyright (c) 2015-2022 Douglas Christopher Wilson <doug@somethingdoug.com>
Rfdc - Copyright 2019 "David Mark Clements <david.mark.clements@gmail.com>"
end-of-stream - Copyright (c) 2014 Mathias Buus
resolve-protobuf-schema - Copyright (c) 2014 Mathias Buus
Tmp - Copyright (c) 2014 KARASZI István
merge-stream - Copyright (c) Stephen Sugden <me@stephensugden.com> (stephensugden.com)
Jsbn - Copyright (c) 2003-2005 Tom Wu
Extsprintf - Copyright (c) 2012, Joyent, Inc. All rights reserved.
jsprim - Copyright (c) 2012, Joyent, Inc. All rights reserved.
Verror - Copyright (c) 2016, Joyent, Inc. All rights reserved.
Readable-stream – Copyright (c) 2016, Joyent, Inc. All rights reserved.
String_decoder - Copyright (c) 2016, Joyent, Inc. All rights reserved.
Jsonfile - Copyright (c) 2012-2015, JP Richardson <jprichardson@gmail.com>
check-more-types - Copyright (c) 2014 Kensho
ci-info - Copyright (c) 2016-2021 Thomas Watson Steen
is-ci - Copyright (c) 2016-2021 Thomas Watson Steen
Universalify - Copyright (c) 2017, Ryan Zimmerman <opensrc@ryanzim.com>
Extend - Copyright (c) 2014 Stefan Thomas
Dayjs - Copyright (c) 2018-present, iamkun @colors/colors Copyright (c) Marak Squires Copyright (c) Sindre Sorhus <sindresorhus@gmail.com> (sindresorhus.com) Copyright (c) DABH (https://github.com/DABH)
@colors/colors - Copyright (c) Marak Squires
ansi-colors - Copyright (c) 2015-present, Brian Woodward.
buffer-crc32 - Copyright (c) 2013 Brian J. Brennan
Getos - Copyright (c) 2016 William Blankenship
@types/sizzle - Copyright (c) Microsoft Corporation.
@types/node - Copyright (c) Microsoft Corporation.
@types/yauzl - Copyright (c) Microsoft Corporation.
@types/sinonjs__fake-timers - Copyright (c) Microsoft Corporation.
@types/pbf – Copyright (c) Microsoft Corporation.
@types/wellknown - Copyright (c) Microsoft Corporation.
request-progress - Copyright (c) 2012 IndigoUnited
requires-port – Copyright (c) 2015 Unshift.io, Arnout Kazemier, the Contributors
url-parse – Copyright (c) 2015 Unshift.io, Arnout Kazemier, the Contributors
util-deprecate - Copyright (c) 2014 Nathan Rajlich <nathan@tootallnate.net>
Debug - Copyright (c) 2014-2017 TJ Holowaychuk tj@vision-media.ca Copyright (c) 2018-2021 Josh Junon
fd-slicer - Copyright (c) 2014 Andrew Kelley
@cypress/xvfb - Original Work Copyright (C) 2012 ProxV, Inc Modified Work Copyright (c) 2015 Cypress.io, LLC Copyright (c) 2014 TJ Holowaychuk tj@vision-media.ca Copyright (c) 2019 Cypress.io, Inc.
@cypress/skip-test - Original Work Copyright (C) 2012 ProxV, Inc Modified Work Copyright (c) 2015 Cypress.io, LLCCopyright (c) 2014 TJ Holowaychuk tj@vision-media.ca Copyright (c) 2019 Cypress.io, Inc.
@cypress/angular
@cypress/mount-utils
@cypress/react
@cypress/react18
@cypress/svelte
@cypress/vue
@cypress/vue2
cypress
Arch - Copyright (c) Feross Aboukhadijeh
cypress-file-upload - Copyright (c) 2019 Pavel Auramenka <pavel.auramenka@gmail.com>
Psl - Copyright (c) 2017 Lupo Montero lupomontero@gmail.com
brace-expansion - Copyright (c) 2013 Julian Gruber <julian@juliangruber.com>
base64-js - Copyright (c) 2014 Jameson Little
lodash.once - Copyright jQuery Foundation and other contributors https://jquery.org/ Copyright and related rights for sample code are waived via CC0. Sample
core-util-is - Copyright Node.js contributors. All rights reserved.
Pump - Copyright (c) 2014 Mathias Buus
Protocol-buffers-schema - Copyright (c) 2014 Mathias Buus
color-name - Copyright (c) 2015 Dmitry Ivanov
lazy-ass - Copyright (c) 2014 Gleb Bahmutov
ecc-jsbn - Copyright (c) 2014 Jeremie Miller
@types/geojson - Copyright (c) Microsoft Corporation
@types/mapbox-gl - Copyright (c) Microsoft Corporation
@types/mapbox__mapbox-gl-draw - Copyright (c) Microsoft Corporation
@types/mapbox__point-geometry - Copyright (c) Microsoft Corporation
@types/mapbox__vector-tile - Copyright (c) Microsoft Corporation
Prettier - Copyright © James Long and contributors
Copyright (c) 2014-present Sebastian McKenzie and other contributors
Process - Copyright (c) 2013 Roman Shtylman <shtylman@gmail.com>
process-nextick-args - Copyright (c) 2013 Roman Shtylman <shtylman@gmail.com>
function-bind - Copyright (c) 2013 Raynos
Geojson - Copyright 2016 Casey Thomas
Xtend - Copyright 2016 Casey Thomas
Querystringify - Copyright (c) 2015 Unshift.io, Arnout Kazemier, the Contributors
vt-pbf - Copyright (c) 2014, Mapbox
Copyright (c) 2015 Anand Thakker
== License Type
MIT
See above for each 4th party dependency
== NAME OF DEPENDENCY 5
Glob - Copyright (c) Isaac Z. Schlueter and Contributors
Semver - Copyright (c) Isaac Z. Schlueter and Contributors
Inflight - Copyright (c) Isaac Z. Schlueter and Contributors
once - Copyright (c) Isaac Z. Schlueter and Contributors
rimraf - Copyright (c) Isaac Z. Schlueter and Contributors
which - Copyright (c) Isaac Z. Schlueter and Contributors
Ini - Copyright (c) Isaac Z. Schlueter and Contributors
minimatch - Copyright (c) Isaac Z. Schlueter and Contributors
yallist - Copyright (c) Isaac Z. Schlueter and Contributors
inherits - Copyright (c) Isaac Z. Schlueter and Contributors
json-stringify-safe - Copyright (c) Isaac Z. Schlueter and Contributors
signal-exit - Copyright (c) Isaac Z. Schlueter and Contributors
lru-cache - Copyright (c) Isaac Z. Schlueter and Contributors
wrappy - Copyright (c) Isaac Z. Schlueter and Contributors
quickselect - Copyright (c) 2018, Vladimir Agafonkin
graceful-fs - Copyright (c) 2011-2022 Isaac Z. Schlueter, Ben Noordhuis, and Contributors
@opensearch-dashboards-test/opensearch-dashboards-test-library - Grant of Copyright License. Subject to the terms and conditions of Copyright OpenSearch Contributors
fs.realpath - Copyright (c) Isaac Z. Schlueter and Contributors Copyright Joyent, Inc. and other Node contributors.
Isexe - Copyright (c) Isaac Z. Schlueter and Contributors
at-least-node - Copyright (c) 2020 Ryan Zimmerman <opensrc@ryanzim.com>
@mapbox/extent - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/geojson-coords - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/geojson-normalize - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/geojson-rewind - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/jsonlint-lines-primitives - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/whoots-js - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@maplibre/maplibre-gl-style-spec - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/mapbox-gl-draw - Copyright (c) 2015, Mapbox
@mapbox/point-geometry - Copyright (c) 2015, Mapbox
Earcut - Copyright (c) 2015, Mapbox
Supercluster - Copyright (c) 2015, Mapbox
geojson-vt - Copyright (c) 2015, Mapbox
Copyright (c) 2018, Mapbox
potpack - Copyright (c) 2015, Mapbox
Kdbush - Copyright (c) 2018, Vladimir Agafonkin
Tinyqueue - Copyright (c) 2018, Vladimir Agafonkin
== License Type
ISC
== NAME OF DEPENDENCY 6
ieee754 - Copyright 2008 Fair Oaks Labs, Inc.
Qs
tough-cookie - Copyright (c) 2015, Salesforce.com, Inc
@mapbox/mapbox-gl-supported
@mapbox/vector-tile
maplibre-gl
Pbf
== License Type
BSD-3-Clause
== NAME OF DEPENDENCY 7
Tweetnacl
== License Type
Unlicense
== NAME OF DEPENDENCY 8
Tslib
Wellknown - Copyright (C) 2013 Tom MacWright tom@macwright.org
Copyright (C) 2004 Sam Hocevar <sam@hocevar.net>
== License Type
BSD
== NAME OF DEPENDENCY 9
extract-zip
@mapbox/geojson-area - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
Copyright (C) 2008 Apple Inc. All Rights Reserved
@mapbox/tiny-sdf - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
@mapbox/unitbezier - Copyright 2005-2013 OpenLayers Contributors. All rights reserved
geojson-flatten
wgs84
rw - Copyright (c) 2014, Michael Bostock
== License Type
BSD-Clause-2
Copyright (c) 2014 Max Ogden and other contributors
== LICENSES
The MIT License (MIT)
Copyright <YEAR> <COPYRIGHT HOLDER>
BSD-Clause 3 License
Copyright (c) 2012-2016, Project contributors
Copyright (c) 2012-2014, Walmart
BSD 2-Clause License
BSD
ISC
Copyright <YEAR> <OWNER>
Unlicense
