Eclipse Parsson Licenses
Eclipse Parsson (org.eclipse.parsson:parsson)
Copyright (c) 2011, 2023 Oracle and/or its affiliates. All rights reserved.
This program and the accompanying materials are made available under the
terms of the Eclipse Public License v. 2.0, which is available at
http://www.eclipse.org/legal/epl-2.0.
This Source Code may also be made available under the following Secondary
Licenses when the conditions for such availability set forth in the
Eclipse Public License v. 2.0 are satisfied: GNU General Public License,
version 2 with the GNU Classpath Exception, which is available at
https://www.gnu.org/software/classpath/license.html.
SPDX-License-Identifier: Eclipse Public License 2.0 + GPL v.2 with CPE
# Notices for Eclipse Parsson
This content is produced and maintained by the Eclipse Parsson project.
* Project home: https://projects.eclipse.org/projects/ee4j.parsson
## Trademarks
Eclipse Parsson is a trademark of the Eclipse Foundation.
## Copyright
All content is the property of the respective authors or their employers. For
more information regarding authorship of content, please consult the listed
source code repository logs.
## Declared Project Licenses
This program and the accompanying materials are made available under the terms
of the Eclipse Public License v. 2.0 which is available at
https://www.eclipse.org/legal/epl-2.0.
SPDX-License-Identifier: EPL-2.0
## Source Code
The project maintains the following source code repositories:
* https://github.com/eclipse-ee4j/parsson
## Third-party Content
This project leverages the following third party content.
None
## Cryptography
Content may contain encryption software. The country in which you are currently
may have restrictions on the import, possession, and use, and/or re-export to
another country, of encryption software. BEFORE using any encryption software,
please check the country's laws, regulations and policies concerning the import,
possession, or use, and re-export of encryption software, to see if this is
permitted.
Eclipse Public License - v 2.0
Eclipse Public License, Version 2.0
GNU General Public License, Version 2
CLASSPATH EXCEPTION
Linking this library statically or dynamically with other modules is
making a combined work based on this library. Thus, the terms and
conditions of the GNU General Public License version 2 cover the whole
combination.
As a special exception, the copyright holders of this library give you
permission to link this library with independent modules to produce an
executable, regardless of the license terms of these independent
modules, and to copy and distribute the resulting executable under
terms of your choice, provided that you also meet, for each linked
independent module, the terms and conditions of the license of that
module. An independent module is a module which is not derived from or
based on this library. If you modify this library, you may extend this
exception to your version of the library, but you are not obligated to
do so. If you do not wish to do so, delete this exception statement
from your version.
Fourth Party Dependencies
"Jakarta JSON Processing API" (jakarta.json:jakarta.json-api)
Licenses:
