JNA License
JNA is dual-licensed under 2 alternative Open Source/Free licenses: LGPL 2.1 and Apache License 2.0. (starting with JNA version 4.0.0).
What this means is that one can choose either one of these licenses (for purposes of re-distributing JNA; usually by including it as one of jars another application or library uses) by downloading corresponding jar file, using it, and living happily everafter.
You may obtain a copy of the LGPL License at:
http://www.gnu.org/licenses/licenses.html
A copy is also included in the downloadable source code package containing JNA, in file "LGPL2.1", under the same directory as this file.
You may obtain a copy of the ASL License at:
http://www.apache.org/licenses/
A copy is also included in the downloadable source code package containing JNA, in file "ASL2.0", under the same directory as this file.
