libwebp Licenses
Copyright (c) 2010, Google Inc. All rights reserved.
BSD 3-Clause License (With Google Inc Reference)
## Files:
PRESUBMIT.py
infra/common.sh
infra/compile.sh
infra/compile_android.sh
infra/compile_js.sh
infra/run_static_analysis.sh
Copyright (c) 2021, Google Inc. All rights reserved.
## Files:
sharpyuv/sharpyuv_dsp.h
Copyright 2022 Google Inc. All Rights Reserved.
Use of this source code is governed by a BSD-style license
that can be found in the COPYING file in the root of the source
tree. An additional intellectual property rights grant can be found
in the file PATENTS. All contributing project authors may
be found in the AUTHORS file in the root of the source tree.
Speed-critical functions for Sharp YUV.
## Files:
imageio/image_enc.h
Copyright 2016 Google Inc. All Rights Reserved.
All-in-one library to save PNG/JPEG/WebP/TIFF/WIC images.
Author: Skal (pascal.massimino@gmail.com)
## Files:
src/dsp/cost_sse2.c
Copyright 2015 Google Inc. All Rights Reserved.
SSE2 version of cost functions
## Files:
src/dsp/dec_clip_tables.c
Copyright 2014 Google Inc. All Rights Reserved.
Clipping tables for filtering
## Files:
src/webp/format_constants.h
Copyright 2012 Google Inc. All Rights Reserved.
Internal header for constants related to WebP file format.
Author: Urvang (urvang@google.com)
## Files:
src/dsp/cost_mips32.c
src/dsp/cost_mips_dsp_r2.c
Author: Djordje Pesut (djordje.pesut@imgtec.com)
## Files:
extras/extras.h
## Files:
src/dsp/filters.c
src/utils/filters_utils.h
Copyright 2011 Google Inc. All Rights Reserved.
Spatial prediction using various filters
## Files:
src/utils/bit_writer_utils.c
Bit writing and boolean coder
Vikas Arora (vikaas.arora@gmail.com)
## Files:
src/enc/alpha_enc.c
Alpha-plane compression.
## Files:
src/webp/mux.h
RIFF container manipulation and encoding for WebP images.
Authors: Urvang (urvang@google.com)
Vikas (vikasa@google.com)
## Files:
sharpyuv/sharpyuv_csp.c
sharpyuv/sharpyuv_csp.h
Colorspace utilities.
## Files:
src/dsp/rescaler_sse2.c
SSE2 Rescaling functions
## Files:
src/dec/vp8i_dec.h
Copyright 2010 Google Inc. All Rights Reserved.
VP8 decoder: internal header.
## Files:
src/dec/quant_dec.c
Quantizer initialization
## Files:
src/enc/syntax_enc.c
Header syntax writing
## Files:
ltmain.sh
This is free software. There is NO warranty; not even for
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Copyright (C) 2004-2019, 2021 Bootstrap Authors
This file is dual licensed under the terms of the MIT license
https://opensource.org/license/MIT, and GPL version 2 or later
http://www.gnu.org/licenses/gpl-2.0.html. You must apply one of
these licenses when using or redistributing this software or any of
the files within it. See the URLs above, or the file `LICENSE`
included in the Bootstrap distribution for the full license texts.
## Files:
src/dsp/filters_mips_dsp_r2.c
Author(s): Branimir Vasic (branimir.vasic@imgtec.com)
## Files:
src/mux/animi.h
Internal header for animation related functions.
Author: Hui Su (huisu@google.com)
## Files:
src/dsp/upsampling_mips_dsp_r2.c
YUV to RGB upsampling functions.
## Files:
src/utils/utils.h
Misc. common utility functions
Authors: Skal (pascal.massimino@gmail.com)
## Files:
tests/fuzzer/animdecoder_fuzzer.cc
Copyright 2020 Google Inc.
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
## Files:
examples/anim_diff.c
Checks if given pair of animated GIF/WebP images are identical:
That is: their reconstructed canvases match pixel-by-pixel and their other
animation properties (loop count etc) also match.
example: anim_diff foo.gif bar.webp
## Files:
src/dec/vp8l_dec.c
main entry for the decoder
Authors: Vikas Arora (vikaas.arora@gmail.com)
Jyrki Alakuijala (jyrki@google.com)
## Files:
src/mux/muxi.h
Internal header for mux library.
## Files:
src/utils/bit_writer_utils.h
## Files:
src/utils/color_cache_utils.h
Color Cache for WebP Lossless
Authors: Jyrki Alakuijala (jyrki@google.com)
Urvang Joshi (urvang@google.com)
## Files:
tests/fuzzer/advanced_api_fuzzer.c
tests/fuzzer/animation_api_fuzzer.c
tests/fuzzer/animencoder_fuzzer.cc
tests/fuzzer/enc_dec_fuzzer.cc
tests/fuzzer/fuzz_utils.h
tests/fuzzer/img_alpha.h
tests/fuzzer/img_grid.h
tests/fuzzer/img_peak.h
tests/fuzzer/mux_demux_api_fuzzer.c
tests/fuzzer/simple_api_fuzzer.c
Copyright 2018 Google Inc.
## Files:
src/utils/bit_reader_utils.h
Boolean decoder
## Files:
src/dsp/alpha_processing_mips_dsp_r2.c
Utilities for processing transparent channel.
## Files:
imageio/wicdec.c
imageio/wicdec.h
Copyright 2013 Google Inc. All Rights Reserved.
Windows Imaging Component (WIC) decode.
## Files:
src/dsp/dec.c
Speed-critical decoding functions, default plain-C implementations.
## Files:
src/dsp/lossless_mips_dsp_r2.c
Image transforms and color space conversion methods for lossless decoder.
Author(s): Djordje Pesut (djordje.pesut@imgtec.com)
Jovan Zelincevic (jovan.zelincevic@imgtec.com)
## Files:
src/dsp/filters_neon.c
Copyright 2017 Google Inc. All Rights Reserved.
NEON variant of alpha filters
## Files:
src/enc/vp8l_enc.c
main entry for the lossless encoder.
Author: Vikas Arora (vikaas.arora@gmail.com)
## Files:
src/dsp/lossless_msa.c
MSA variant of methods for lossless decoder
Author: Prashant Patil (prashant.patil@imgtec.com)
## Files:
src/dsp/enc.c
Speed-critical encoding functions.
## Files:
src/dsp/cost.c
## Files:
src/utils/quant_levels_dec_utils.c
Implement gradient smoothing: we replace a current alpha value by its
surrounding average if it's close enough (that is: the change will be less
than the minimum distance between two quantized level).
We use sliding window for computing the 2d moving average.
## Files:
src/dec/alpha_dec.c
Alpha-plane decompression.
## Files:
src/webp/demux.h
Demux API.
Enables extraction of image and extended format data from WebP files.
## Files:
extras/get_disto.c
Simple tool to load two webp/png/jpg/tiff files and compute PSNR/SSIM.
This is mostly a wrapper around WebPPictureDistortion().
## Files:
src/dsp/upsampling_sse41.c
SSE41 version of YUV to RGB upsampling functions.
Author: somnath@google.com (Somnath Banerjee)
## Files:
sharpyuv/sharpyuv_cpu.c
sharpyuv/sharpyuv_cpu.h
## Files:
PATENTS
Additional IP Rights Grant (Patents)
"These implementations" means the copyrightable works that implement the WebM
codecs distributed by Google as part of the WebM Project.
Google hereby grants to you a perpetual, worldwide, non-exclusive, no-charge,
royalty-free, irrevocable (except as stated in this section) patent license to
make, have made, use, offer to sell, sell, import, transfer, and otherwise
run, modify and propagate the contents of these implementations of WebM, where
such license applies only to those patent claims, both currently owned by
Google and acquired in the future, licensable by Google that are necessarily
infringed by these implementations of WebM. This grant does not include claims
that would be infringed only as a consequence of further modification of these
implementations. If you or your agent or exclusive licensee institute or order
or agree to the institution of patent litigation or any other patent
enforcement activity against any entity (including a cross-claim or
counterclaim in a lawsuit) alleging that any of these implementations of WebM
or any code incorporated within any of these implementations of WebM
constitute direct or contributory patent infringement, or inducement of
patent infringement, then any patent rights granted to you under this License
for these implementations of WebM shall terminate as of the date such
litigation is filed.
## Files:
imageio/image_dec.h
All-in-one library to decode PNG/JPEG/WebP/TIFF/WIC input images.
## Files:
src/dsp/lossless.c
## Files:
src/dsp/yuv_sse2.c
src/dsp/yuv_sse41.c
YUV->RGB conversion functions
## Files:
src/dsp/lossless_common.h
Vincent Rabaud (vrabaud@google.com)
## Files:
src/dsp/rescaler_msa.c
MSA version of rescaling functions
## Files:
src/mux/anim_encode.c
AnimEncoder implementation.
## Files:
src/utils/huffman_utils.c
src/utils/huffman_utils.h
Utilities for building and looking up Huffman trees.
Author: Urvang Joshi (urvang@google.com)
## Files:
src/dsp/lossless_enc_mips_dsp_r2.c
Image transform methods for lossless encoder.
## Files:
src/utils/thread_utils.c
src/utils/thread_utils.h
Multi-threaded worker
## Files:
imageio/image_dec.c
Generic image-type guessing.
## Files:
src/utils/color_cache_utils.c
Author: Jyrki Alakuijala (jyrki@google.com)
## Files:
src/dec/vp8li_dec.h
Lossless decoder: internal header.
Vikas Arora(vikaas.arora@gmail.com)
## Files:
src/dsp/dec_neon.c
ARM NEON version of dsp functions and loop filtering.
Authors: Somnath Banerjee (somnath@google.com)
Johann Koenig (johannkoenig@google.com)
## Files:
src/dsp/quant.h
Copyright 2018 Google Inc. All Rights Reserved.
## Files:
src/dsp/ssim_sse2.c
SSE2 version of distortion calculation
## Files:
src/dec/common_dec.h
Definitions and macros common to encoding and decoding
## Files:
src/dsp/yuv.h
## Files:
examples/unicode_gif.h
giflib doesn't have a Unicode DGifOpenFileName(). Let's make one.
Author: Yannis Guyon (yguyon@google.com)
## Files:
src/dec/webpi_dec.h
Internal header: WebP decoding parameters and custom IO on buffer
## Files:
examples/img2webp.c
generate an animated WebP out of a sequence of images
(PNG, JPEG, ...)
Example usage:
Author: skal@google.com (Pascal Massimino)
## Files:
src/webp/mux_types.h
Data-types common to the mux and demux libraries.
## Files:
src/dsp/enc_neon.c
ARM NEON version of speed-critical encoding functions.
adapted from libvpx (https://www.webmproject.org/code/)
## Files:
src/enc/picture_tools_enc.c
WebPPicture tools: alpha handling, etc.
## Files:
imageio/pnmdec.h
partial PNM format decoder (ppm/pgm)
## Files:
src/dsp/dsp.h
Speed-critical functions.
## Files:
src/enc/histogram_enc.h
Models the histograms of literal and distance codes.
## Files:
src/utils/quant_levels_dec_utils.h
Alpha plane de-quantization utility
Author: Vikas Arora (vikasa@google.com)
## Files:
src/utils/huffman_encode_utils.h
Entropy encoding (Huffman) for webp lossless
## Files:
imageio/imageio_util.c
imageio/imageio_util.h
Utility functions used by the image decoders.
## Files:
src/enc/picture_csp_enc.c
WebPPicture utils for colorspace conversion
## Files:
examples/cwebp.c
simple command line calling the WebPEncode function.
Encodes a raw .YUV into WebP bitstream
## Files:
src/dec/io_dec.c
functions for sample output.
## Files:
examples/dwebp.c
Command-line tool for decoding a WebP image.
## Files:
src/enc/backward_references_cost_enc.c
Improves a given set of backward references by analyzing its bit cost.
The algorithm is similar to the Zopfli compression algorithm but tailored to
images.
Author: Vincent Rabaud (vrabaud@google.com)
## Files:
src/enc/filter_enc.c
Selecting filter level
## Files:
src/enc/config_enc.c
Coding tools configuration
## Files:
imageio/webpdec.c
imageio/webpdec.h
WebP decode.
## Files:
src/dsp/lossless_neon.c
NEON variant of methods for lossless decoder
## Files:
sharpyuv/sharpyuv_gamma.c
sharpyuv/sharpyuv_gamma.h
Gamma correction utilities.
## Files:
src/dsp/dec_msa.c
MSA version of dsp functions
Author(s): Prashant Patil (prashant.patil@imgtec.com)
## Files:
imageio/tiffdec.c
imageio/tiffdec.h
TIFF decode.
## Files:
src/webp/decode.h
Main decoding functions for WebP images.
## Files:
src/dec/vp8_dec.h
Low-level API for VP8 decoder
## Files:
examples/gifdec.h
GIF decode.
## Files:
ltmain.sh
Copyright (C) 1996-2019, 2021-2022 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
## Files:
src/dsp/lossless.h
## Files:
src/dsp/mips_macro.h
MIPS common macros
## Files:
src/dsp/rescaler_neon.c
NEON version of rescaling functions
## Files:
src/dsp/msa_macro.h
MSA common macros
## Files:
src/dec/frame_dec.c
Frame-reconstruction function. Memory allocation.
## Files:
src/dsp/yuv_mips32.c
MIPS version of YUV to RGB upsampling functions.
## Files:
src/enc/iterator_enc.c
VP8Iterator: block iterator
## Files:
src/dsp/enc_msa.c
MSA version of encoder dsp functions.
## Files:
src/utils/bit_reader_utils.c
Boolean decoder non-inlined methods
## Files:
examples/gif2webp.c
simple tool to convert animated GIFs to WebP
## Files:
extras/webp_to_sdl.c
extras/webp_to_sdl.h
Simple WebP-to-SDL wrapper. Useful for emscripten.
Author: James Zern (jzern@google.com)
## Files:
src/enc/picture_psnr_enc.c
WebPPicture tools for measuring distortion
## Files:
src/dsp/enc_sse41.c
SSE4 version of some encoding functions.
## Files:
src/dsp/yuv_neon.c
## Files:
src/utils/utils.c
## Files:
examples/anim_dump.c
Decodes an animated WebP file and dumps the decoded frames as PNG or TIFF.
## Files:
src/dsp/ssim.c
## Files:
src/demux/demux.c
WebP container demux.
## Files:
src/dsp/filters_msa.c
MSA variant of alpha filters
## Files:
src/dec/vp8_dec.c
## Files:
src/enc/cost_enc.c
Cost tables for level and modes
## Files:
imageio/pnmdec.c
(limited) PNM decoder
## Files:
src/dec/buffer_dec.c
Everything about WebPDecBuffer
## Files:
src/dsp/rescaler_mips32.c
src/dsp/rescaler_mips_dsp_r2.c
MIPS version of rescaling functions
## Files:
src/dsp/alpha_processing_sse2.c
## Files:
extras/vwebp_sdl.c
Simple SDL-based WebP file viewer.
Does not support animation, just static images.
Press 'q' to exit.
## Files:
src/dsp/lossless_sse2.c
SSE2 variant of methods for lossless decoder
## Files:
src/webp/types.h
Common types + memory wrappers
## Files:
src/dsp/lossless_enc_msa.c
MSA variant of Image transform methods for lossless encoder.
Authors: Prashant Patil (Prashant.Patil@imgtec.com)
## Files:
src/webp/encode.h
WebP encoder: main interface
## Files:
imageio/image_enc.c
Save image
## Files:
examples/gifdec.c
GIF decode.
## Files:
src/mux/muxinternal.c
Internal objects and utils for mux.
## Files:
examples/webpinfo.c
Command-line tool to print out the chunk level structure of WebP files
along with basic integrity checks.
## Files:
src/dsp/common_sse41.h
SSE4 code common to several files.
## Files:
src/enc/analysis_enc.c
Macroblock analysis
## Files:
src/dsp/yuv_mips_dsp_r2.c
MIPS DSPr2 version of YUV to RGB upsampling functions.
## Files:
src/enc/token_enc.c
Paginated token buffer
A 'token' is a bit value associated with a probability, either fixed
or a later-to-be-determined after statistics have been collected.
For dynamic probability, we just record the slot id (idx) for the probability
value in the final probability array (uint8_t* probas in VP8EmitTokens).
## Files:
src/utils/quant_levels_utils.h
Alpha plane quantization utility
## Files:
sharpyuv/sharpyuv_dsp.c
sharpyuv/sharpyuv_neon.c
sharpyuv/sharpyuv_sse2.c
## Files:
src/dsp/upsampling.c
## Files:
src/dec/idec_dec.c
Incremental decoding
## Files:
src/dsp/dec_mips32.c
src/dsp/dec_mips_dsp_r2.c
MIPS version of dsp functions
## Files:
src/enc/picture_rescale_enc.c
WebPPicture tools: copy, crop, rescaling and view.
## Files:
examples/stopwatch.h
Helper functions to measure elapsed time.
Author: Mikolaj Zalewski (mikolajz@google.com)
## Files:
src/enc/vp8li_enc.h
Lossless encoder: internal header.
## Files:
examples/webpmux.c
Simple command-line to create a WebP container file and to extract or strip
relevant data from the container file.
Authors: Vikas (vikaas.arora@gmail.com),
## Files:
src/dsp/cpu.c
CPU detection
Author: Christian Duvivier (cduvivier@google.com)
## Files:
src/dsp/common_sse2.h
SSE2 code common to several files.
## Files:
src/enc/quant_enc.c
Quantization
## Files:
extras/extras.c
Additional WebP utilities.
## Files:
src/utils/quant_levels_utils.c
Quantize levels for specified number of quantization-levels ([2, 256]).
Min and max values are preserved (usual 0 and 255 for alpha plane).
## Files:
src/enc/cost_enc.h
Cost tables for level and modes.
## Files:
src/enc/near_lossless_enc.c
Near-lossless image preprocessing adjusts pixel values to help
compressibility with a guarantee of maximum deviation between original and
resulting pixel values.
Converted to C by Aleksander Kramarz (akramarz@google.com)
## Files:
src/utils/bit_reader_inl_utils.h
Specific inlined methods for boolean decoder [VP8GetBit() ...]
This file should be included by the .c sources that actually need to call
these methods.
## Files:
examples/example_util.c
examples/example_util.h
Utility functions used by the example programs.
## Files:
src/utils/huffman_encode_utils.c
Entropy encoding (Huffman) for webp lossless.
## Files:
src/dsp/upsampling_neon.c
NEON version of YUV to RGB upsampling functions.
Author: mans@mansr.com (Mans Rullgard)
Based on SSE code by: somnath@google.com (Somnath Banerjee)
## Files:
src/dsp/neon.h
NEON common code.
## Files:
src/dsp/dec_sse2.c
SSE2 version of some decoding functions (idct, loop filtering).
cduvivier@google.com (Christian Duvivier)
## Files:
src/utils/filters_utils.c
filter estimation
## Files:
ltmain.sh
GNU Libtool is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
As a special exception to the GNU General Public License,
if you distribute this file as part of a program or library that
is built using GNU Libtool, you may include this file under the
same distribution terms that you use for the rest of that program.
GNU Libtool is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
## Files:
src/dsp/lossless_enc_mips32.c
MIPS version of lossless functions
## Files:
src/utils/random_utils.c
src/utils/random_utils.h
Pseudo-random utilities
## Files:
src/dsp/alpha_processing_neon.c
Utilities for processing transparent channel, NEON version.
## Files:
src/dsp/enc_mips32.c
MIPS version of speed-critical encoding functions.
Slobodan Prijic (slobodan.prijic@imgtec.com)
## Files:
src/enc/vp8i_enc.h
WebP encoder: internal header.
## Files:
src/dsp/filters_sse2.c
SSE2 variant of alpha filters
## Files:
src/dsp/lossless_enc_sse41.c
SSE4.1 variant of methods for lossless encoder
## Files:
src/enc/predictor_enc.c
## Files:
src/mux/muxread.c
## Files:
extras/quality_estimate.c
VP8EstimateQuality(): rough encoding quality estimate
## Files:
examples/anim_util.c
examples/anim_util.h
Utilities for animated images
## Files:
src/dsp/upsampling_msa.c
MSA version of YUV to RGB upsampling functions.
## Files:
src/dsp/lossless_enc_sse2.c
SSE2 variant of methods for lossless encoder
## Files:
swig/libwebp.swig
libwebp swig interface definition
## Files:
src/utils/rescaler_utils.c
src/utils/rescaler_utils.h
Rescaling functions
## Files:
src/demux/anim_decode.c
AnimDecoder implementation.
## Files:
src/enc/backward_references_enc.c
src/enc/backward_references_enc.h
src/enc/histogram_enc.c
## Files:
src/enc/tree_enc.c
Coding of token probabilities, intra modes and segments.
## Files:
src/dsp/cost_neon.c
ARM NEON version of cost functions
## Files:
src/enc/picture_enc.c
WebPPicture class basis
## Files:
src/dec/webp_dec.c
Main decoding functions for WEBP images.
## Files:
src/dsp/lossless_enc.c
## Files:
imageio/pngdec.c
imageio/pngdec.h
PNG decode.
## Files:
src/dec/tree_dec.c
Coding trees and probas
## Files:
src/dsp/lossless_sse41.c
Copyright 2021 Google Inc. All Rights Reserved.
SSE41 variant of methods for lossless decoder
## Files:
src/dsp/enc_mips_dsp_r2.c
Author(s): Darko Laus (darko.laus@imgtec.com)
Mirko Raus (mirko.raus@imgtec.com)
## Files:
ltmain.sh
func_version
Echo version message to standard output and exit.
The version message is extracted from the calling file's header
comments, with leading '# ' stripped:
1. First display the progname and version
2. Followed by the header comment line matching /^# Written by /
3. Then a blank line followed by the first following line matching
/^# Copyright /
4. Immediately followed by any lines between the previous matches,
except lines preceding the intervening completely blank line.
For example, see the header comments of this file.
## Files:
sharpyuv/sharpyuv.h
Sharp RGB to YUV conversion.
## Files:
src/dsp/yuv.c
## Files:
src/dsp/cpu.h
CPU detection functions and macros.
## Files:
sharpyuv/sharpyuv.c
## Files:
src/dsp/upsampling_sse2.c
SSE2 version of YUV to RGB upsampling functions.
## Files:
src/utils/endian_inl_utils.h
Endian related functions.
## Files:
examples/vwebp.c
Simple OpenGL-based WebP file viewer.
## Files:
imageio/jpegdec.c
imageio/jpegdec.h
JPEG decode.
## Files:
src/dsp/alpha_processing_sse41.c
Utilities for processing transparent channel, SSE4.1 variant.
## Files:
src/enc/webp_enc.c
WebP encoder: main entry point
## Files:
imageio/metadata.c
imageio/metadata.h
Metadata types and functions.
## Files:
.cmake-format.py
If comment markup is enabled, don't reflow the first comment block in each
listfile. Use this to preserve formatting of your copyright/license
statements.
## Files:
src/enc/frame_enc.c
frame coding and analysis
## Files:
src/dsp/dec_sse41.c
SSE4 version of some decoding functions.
## Files:
src/dec/alphai_dec.h
Alpha decoder: internal header.
## Files:
src/dsp/alpha_processing.c
## Files:
src/mux/muxedit.c
Set and delete APIs for mux.
## Files:
ltmain.sh
Copyright (C) 2010-2019, 2021 Bootstrap Authors
## Files:
examples/unicode.h
Unicode support for Windows. The main idea is to maintain an array of Unicode
arguments (wargv) and use it only for file paths. The regular argv is used
for everything else.
## Files:
src/dsp/enc_sse2.c
SSE2 version of speed-critical encoding functions.
## Files:
src/dsp/rescaler.c
Rescaling functions
## Files:
src/dsp/lossless_enc_neon.c
NEON variant of methods for lossless encoder
