netty Licenses
------------------------------- Top-level license --------------------------
https://github.com/netty/netty/blob/netty-4.1.113.Final/LICENSE.txt
Apache License
Apache License, Version 2.0
------------------------------- Copyright notices --------------------------
https://github.com/netty/netty/blob/netty-4.1.113.Final/NOTICE.txt
The Netty Project
Please visit the Netty web site for more information:
* https://netty.io/
Copyright 2014 The Netty Project
The Netty Project licenses this file to you under the Apache License,
version 2.0 (the "License"); you may not use this file except in compliance
with the License. You may obtain a copy of the License at:
https://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
License for the specific language governing permissions and limitations
under the License.
Also, please refer to each LICENSE.<component>.txt file, which is located in
the 'license' directory of the distribution file, for the license terms of the
components that this product depends on.
This product contains the extensions to Java Collections Framework which has
been derived from the works by JSR-166 EG, Doug Lea, and Jason T. Greene:
* LICENSE:
* license/LICENSE.jsr166y.txt (Public Domain)
* HOMEPAGE:
* http://gee.cs.oswego.edu/cgi-bin/viewcvs.cgi/jsr166/
* http://viewvc.jboss.org/cgi-bin/viewvc.cgi/jbosscache/experimental/jsr166/
This product contains a modified version of Robert Harder's Public Domain
Base64 Encoder and Decoder, which can be obtained at:
* LICENSE:
* license/LICENSE.base64.txt (Public Domain)
* HOMEPAGE:
* http://iharder.sourceforge.net/current/java/base64/
This product contains a modified portion of 'Webbit', an event based
WebSocket and HTTP server, which can be obtained at:
* LICENSE:
* license/LICENSE.webbit.txt (BSD License)
* HOMEPAGE:
* https://github.com/joewalnes/webbit
This product contains a modified portion of 'SLF4J', a simple logging
facade for Java, which can be obtained at:
* LICENSE:
* license/LICENSE.slf4j.txt (MIT License)
* HOMEPAGE:
* https://www.slf4j.org/
This product contains a modified portion of 'Apache Harmony', an open source
Java SE, which can be obtained at:
* NOTICE:
* license/NOTICE.harmony.txt
* LICENSE:
* license/LICENSE.harmony.txt (Apache License 2.0)
* HOMEPAGE:
* https://archive.apache.org/dist/harmony/
This product contains a modified portion of 'jbzip2', a Java bzip2 compression
and decompression library written by Matthew J. Francis. It can be obtained at:
* LICENSE:
* license/LICENSE.jbzip2.txt (MIT License)
* HOMEPAGE:
* https://code.google.com/p/jbzip2/
This product contains a modified portion of 'libdivsufsort', a C API library to construct
the suffix array and the Burrows-Wheeler transformed string for any input string of
a constant-size alphabet written by Yuta Mori. It can be obtained at:
* LICENSE:
* license/LICENSE.libdivsufsort.txt (MIT License)
* HOMEPAGE:
* https://github.com/y-256/libdivsufsort
This product contains a modified portion of Nitsan Wakart's 'JCTools', Java Concurrency Tools for the JVM,
* LICENSE:
* license/LICENSE.jctools.txt (ASL2 License)
* HOMEPAGE:
* https://github.com/JCTools/JCTools
This product optionally depends on 'JZlib', a re-implementation of zlib in
pure Java, which can be obtained at:
* LICENSE:
* license/LICENSE.jzlib.txt (BSD style License)
* HOMEPAGE:
* http://www.jcraft.com/jzlib/
This product optionally depends on 'Compress-LZF', a Java library for encoding and
decoding data in LZF format, written by Tatu Saloranta. It can be obtained at:
* LICENSE:
* license/LICENSE.compress-lzf.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/ning/compress
This product optionally depends on 'lz4', a LZ4 Java compression
and decompression library written by Adrien Grand. It can be obtained at:
* LICENSE:
* license/LICENSE.lz4.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/jpountz/lz4-java
This product optionally depends on 'lzma-java', a LZMA Java compression
and decompression library, which can be obtained at:
* LICENSE:
* license/LICENSE.lzma-java.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/jponge/lzma-java
This product optionally depends on 'zstd-jni', a zstd-jni Java compression
* LICENSE:
* license/LICENSE.zstd-jni.txt (BSD)
* HOMEPAGE:
* https://github.com/luben/zstd-jni
This product contains a modified portion of 'jfastlz', a Java port of FastLZ compression
and decompression library written by William Kinney. It can be obtained at:
* LICENSE:
* license/LICENSE.jfastlz.txt (MIT License)
* HOMEPAGE:
* https://code.google.com/p/jfastlz/
This product contains a modified portion of and optionally depends on 'Protocol Buffers', Google's data
interchange format, which can be obtained at:
* LICENSE:
* license/LICENSE.protobuf.txt (New BSD License)
* HOMEPAGE:
* https://github.com/google/protobuf
This product optionally depends on 'Bouncy Castle Crypto APIs' to generate
a temporary self-signed X.509 certificate when the JVM does not provide the
equivalent functionality. It can be obtained at:
* LICENSE:
* license/LICENSE.bouncycastle.txt (MIT License)
* HOMEPAGE:
* https://www.bouncycastle.org/
This product optionally depends on 'Snappy', a compression library produced
by Google Inc, which can be obtained at:
* LICENSE:
* license/LICENSE.snappy.txt (New BSD License)
* HOMEPAGE:
* https://github.com/google/snappy
This product optionally depends on 'JBoss Marshalling', an alternative Java
serialization API, which can be obtained at:
* LICENSE:
* license/LICENSE.jboss-marshalling.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/jboss-remoting/jboss-marshalling
This product optionally depends on 'Caliper', Google's micro-
benchmarking framework, which can be obtained at:
* LICENSE:
* license/LICENSE.caliper.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/google/caliper
This product optionally depends on 'Apache Commons Logging', a logging
* LICENSE:
* license/LICENSE.commons-logging.txt (Apache License 2.0)
* HOMEPAGE:
* https://commons.apache.org/logging/
This product optionally depends on 'Apache Log4J', a logging framework, which
can be obtained at:
* LICENSE:
* license/LICENSE.log4j.txt (Apache License 2.0)
* HOMEPAGE:
* https://logging.apache.org/log4j/
This product optionally depends on 'Aalto XML', an ultra-high performance
non-blocking XML processor, which can be obtained at:
* LICENSE:
* license/LICENSE.aalto-xml.txt (Apache License 2.0)
* HOMEPAGE:
* https://wiki.fasterxml.com/AaltoHome
This product contains a modified version of 'HPACK', a Java implementation of
the HTTP/2 HPACK algorithm written by Twitter. It can be obtained at:
* LICENSE:
* license/LICENSE.hpack.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/twitter/hpack
the HTTP/2 HPACK algorithm written by Cory Benfield. It can be obtained at:
* LICENSE:
* license/LICENSE.hyper-hpack.txt (MIT License)
* HOMEPAGE:
* https://github.com/python-hyper/hpack/
the HTTP/2 HPACK algorithm written by Tatsuhiro Tsujikawa. It can be obtained at:
* LICENSE:
* license/LICENSE.nghttp2-hpack.txt (MIT License)
* HOMEPAGE:
* https://github.com/nghttp2/nghttp2/
This product contains a modified portion of 'Apache Commons Lang', a Java library
provides utilities for the java.lang API, which can be obtained at:
* LICENSE:
* license/LICENSE.commons-lang.txt (Apache License 2.0)
* HOMEPAGE:
* https://commons.apache.org/proper/commons-lang/
This product contains the Maven wrapper scripts from 'Maven Wrapper', that provides an easy way to ensure a user has everything necessary to run the Maven build.
* LICENSE:
* license/LICENSE.mvn-wrapper.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/takari/maven-wrapper
This product contains the dnsinfo.h header file, that provides a way to retrieve the system DNS configuration on MacOS.
This private header is also used by Apple's open source
mDNSResponder (https://opensource.apple.com/tarballs/mDNSResponder/).
* LICENSE:
* license/LICENSE.dnsinfo.txt (Apple Public Source License 2.0)
* HOMEPAGE:
* https://www.opensource.apple.com/source/configd/configd-453.19/dnsinfo/dnsinfo.h
This product optionally depends on 'Brotli4j', Brotli compression and
decompression for Java., which can be obtained at:
* LICENSE:
* license/LICENSE.brotli4j.txt (Apache License 2.0)
* HOMEPAGE:
* https://github.com/hyperxpro/Brotli4j
