Oracle JET License
# Oracle JET 17.0.1
You may not use the identified files except in compliance with the Universal Permissive License (UPL), Version 1.0 (the "License.")
You may obtain a copy of the License at https://opensource.org/licenses/UPL. A copy of the license is also reproduced below.
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and limitations under the License.
Copyright (c) 2014, 2024 Oracle and/or its affiliates
The Universal Permissive License (UPL), Version 1.0
Subject to the condition set forth below, permission is hereby granted to any person obtaining
a copy of this software, associated documentation and/or data (collectively the "Software"),
free of charge and under any and all copyright rights in the Software, and any and all patent
rights owned or freely licensable by each licensor hereunder covering either (i) the unmodified
Software as contributed to or provided by such licensor, or (ii) the Larger Works (as defined below),
to deal in both
(a) the Software, and (b) any piece of software and/or hardware listed in the lrgrwrks.txt file if
one is included with the Software (each a Larger Work to which the Software is contributed by such licensors),
without restriction, including without limitation the rights to copy, create derivative works of,
display, perform, and distribute the Software and make, use, sell, offer for sale, import, export,
have made, and have sold the Software and the Larger Work(s), and to sublicense the foregoing rights
on either these or other terms.
This license is subject to the following condition:
The above copyright notice and either this complete permission notice or at a minimum a reference
to the UPL must be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH
THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
DO NOT TRANSLATE OR LOCALIZE.
Oracle elects to use only the GNU Lesser General Public License version 2.1
(LGPL) for any software where a choice of LGPL/GPL license versions are made
available with the language indicating that LGPLv2.1/GPLv2 or any later version
may be used, or where a choice of which version of the LGPL/GPL is applied is
unspecified.
THIRD-PARTY COMPONENT FILE LICENSE
(path in the installation) (see license text reproduced below)
js/libs/chai/chai.js MIT
js/libs/hammer/hammer.js MIT
js/libs/js-signals/signals.js MIT
js/libs/jquery/jquery.js MIT
js/libs/jquery/jquery-ui-.custom.js MIT
js/libs/jquery/jqueryui-amd/core.js MIT
js/libs/jquery/jqueryui-amd/draggable.js MIT
js/libs/jquery/jqueryui-amd/mouse.js MIT
js/libs/jquery/jqueryui-amd/position.js MIT
js/libs/jquery/jqueryui-amd/sortable.js MIT
js/libs/jquery/jqueryui-amd/widget.js MIT
js/libs/jquery/jqueryui-amd/disable-selection.js MIT
js/libs/jquery/jqueryui-amd/jquery-var-for-color.js MIT
js/libs/jquery/jqueryui-amd/ie.js MIT
js/libs/jquery/jqueryui-amd/keycode.js MIT
js/libs/jquery/jqueryui-amd/jquery-patch.js MIT
js/libs/jquery/jqueryui-amd/labels.js MIT
js/libs/jquery/jqueryui-amd/form-reset-mixin.js MIT
js/libs/jquery/jqueryui-amd/unique-id.js MIT
js/libs/jquery/jqueryui-amd/scroll-parent.js MIT
js/libs/jquery/jqueryui-amd/tabbable.js MIT
js/libs/jquery/jqueryui-amd/version.js MIT
js/libs/jquery/jqueryui-amd/focusable.js MIT
js/libs/jquery/jqueryui-amd/data.js MIT
js/libs/jquery/jqueryui-amd/effect.js MIT
js/libs/jquery/jqueryui-amd/safe-blur.js MIT
js/libs/jquery/jqueryui-amd/form.js MIT
js/libs/jquery/jqueryui-amd/safe-active-element.js MIT
js/libs/jquery/jqueryui-amd/plugin.js MIT
js/libs/jquery/jqueryui-amd/widgets/sortable.js MIT
js/libs/jquery/jqueryui-amd/widgets/draggable.js MIT
js/libs/jquery/jqueryui-amd/widgets/mouse.js MIT
js/libs/jquery/jqueryui-amd/vendor/jquery-color/jquery.color.js MIT
js/libs/knockout/knockout.js MIT
js/libs/oj/v17.0.1/min/ojcspexpressionevaluator.js (cspexpressionevaluator.js) MIT
js/libs/oj/v17.0.1/min/ojexpparser.js (expparser.js) MIT
js/libs/oj/v17.0.1/min/ojknockout.js (knockout-fast-foreach.js) MIT
js/libs/oj/v17.0.1/min/ojmessagebanner.js (Ramda) MIT
js/libs/oj/v17.0.1/min/ojselectcombobox.js (Select2.js) Apache 2.0
js/libs/oj/v17.0.1/min/ojtree.js (jsTree.js) MIT
js/libs/oj/v17.0.1/ojL10n.js (requireJS i18n) MIT
js/libs/proj4js/dist/proj4.js MIT
js/libs/require/require.js MIT
js/libs/require/text.js MIT
js/libs/require-css/css.min.js (require-css) MIT
scss/oj/v17.0.1/3rdparty/normalize/normalize.scss MIT
js/libs/touchr/touchr.js MIT
js/libs/preact/dist/preact.umd.js MIT
Chai
https://github.com/chaijs/chai
Copyright (c) 2017 Chai.js Assertion Library
expression-eval
https://github.com/donmccurdy/expression-eval
Copyright (c) 2017 Don McCurdy
jsep
https://github.com/soney/jsep
Copyright (c) 2013 Stephen Oney, https://ericsmekens.github.io/jsep/
Knockout Fast Foreach v0.6.0 (2016-07-28T11:02:54.197Z)
By: Brian M Hunt (C) 2015 | License: MIT
proj4js
http://proj4js.org/
Copyright (C) 2014 Mike Adair, Richard Greenwood, Didier Richard, Stephen Irons, Olivier Terral and Calvin Metcalf;
Licensed under the MIT license
require-css
https://github.com/guybedford/require-css
Copyright (C) 2013 Guy Bedford
Hammer.JS
http://hammerjs.github.io/
Copyright (C) 2011-2017 by Jorik Tangelder (Eight Media)
Foundation Responsive Library
http://foundation.zurb.com
Normalize.scss
Copyright © Nicolas Gallagher and Jonathan Neal
RequireJS i18n
http://github.com/requirejs/i18n for details
Copyright (c) 2010-2011, The Dojo Foundation
jsTree http://jstree.com/
Copyright (c) 2012 Ivan Bozhanov (http://vakata.com)
select2.js
https://github.com/select2/select2
Copyright 2012 Igor Vaynberg
This software is licensed under the Apache License, Version 2.0 (the "Apache License") or the GNU
General Public License version 2 (the "GPL License"). You may choose either license to govern your use of this software only upon the condition that you accept all of the terms of either the Apache License or the GPL License.
You may obtain a copy of the Apache License and the GPL License at:
http://www.apache.org/licenses/LICENSE-2.0
http://www.gnu.org/licenses/gpl-2.0.html
Apache License or the GPL Licesnse is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied. See the Apache License and the GPL License for
the specific language governing permissions and limitations under the Apache License and the GPL License.
jQuery UI
http://jqueryui.com
Includes: core.js, widget.js, mouse.js, position.js, draggable.js, sortable.js
jQuery JavaScript Library
http://jquery.com/
Copyright OpenJS Foundation and other contributors, https://openjsf.org/
JS Signals <http://millermedeiros.github.com/js-signals/>
Author: Miller Medeiros
RequireJS text
http://github.com/requirejs/text
Copyright jQuery Foundation and other contributors, https://jquery.org/
RequireJS
http://github.com/jrburke/requirejs
Knockout JavaScript library
Copyright (c) 2010 Steven Sanderson, the Knockout.js team, and other contributors
http://knockoutjs.com/
Preact
The MIT License (MIT)
Copyright (c) 2015-present Jason Miller
Ramda
https://github.com/ramda/ramda
Copyright (c) 2013-2020 Scott Sauyet and Michael Hurley
========================= Apache-2.0 =========================
The following applies to all products licensed under the Apache 2.0 License:
You may not use the identified files except in compliance with the Apache
License, Version 2.0 (the "License.")
You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0.
under the License.
Apache License
========================= Proj4js =========================
Mike Adair madairATdmsolutions.ca
Richard Greenwood richATgreenwoodmap.com
Didier Richard didier.richardATign.fr
Stephen Irons stephen.ironsATclear.net.nz
Olivier Terral oterralATgmail.com
Calvin Metcalf cmetcalfATappgeo.com
Copyright (c) 2014, Mike Adair, Richard Greenwood, Didier Richard, Stephen Irons, Olivier Terral and Calvin Metcalf
