pywinrm Licenses
Copyright: Alexey Diyan
License: MIT
./LICENSE
Copyright (c) 2013 Alexey Diyan
-------------- Separator --------------
Dependency: :certifi
Copyright: Kenneth Reitz
License: MPL 2.0
./LICENSE
This package contains a modified version of ca-bundle.crt:
ca-bundle.crt -- Bundle of CA Root Certificates
Certificate data from Mozilla as of: Thu Nov 3 19:04:19 2011#
This is a bundle of X.509 certificates of public Certificate Authorities
(CA). These were automatically extracted from Mozilla's root certificates
file (certdata.txt). This file can be found in the mozilla source tree:
http://mxr.mozilla.org/mozilla/source/security/nss/lib/ckfw/builtins/certdata.txt?raw=1#
It contains the certificates in PEM format and therefore
can be directly used with curl / libcurl / php_curl, or with
an Apache+mod_ssl webserver for SSL client authentication.
Just configure this file as the SSLCACertificateFile.#
***** BEGIN LICENSE BLOCK *****
This Source Code Form is subject to the terms of the Mozilla Public License,
v. 2.0. If a copy of the MPL was not distributed with this file, You can obtain
one at http://mozilla.org/MPL/2.0/.
***** END LICENSE BLOCK *****
@(#) $RCSfile: certdata.txt,v $ $Revision: 1.80 $ $Date: 2011/11/03 15:11:58 $
https://www.mozilla.org/en-US/MPL/2.0/
Mozilla Public License, Version 2.0
Dependency: :cffi
Copyright: Armin Rigo, Maciej Fijalkowski
License: MIT
./LICENSE
Except when otherwise stated (look for LICENSE files in directories or
information at the beginning of each file) all software and
documentation is licensed as follows:
The MIT License
Dependency: :charset-normalizer
Copyright: Ahmed TAHRI
License: MIT
./LICENSE
MIT License
Copyright (c) 2019 TAHRI Ahmed R.
Dependency: :cryptography
Copyright: The Python Cryptographic Authority and individual contributors
License: Apache 2.0; BSD 3-Clause
./LICENSE
This software is made available under the terms of *either* of the licenses
found in LICENSE.APACHE or LICENSE.BSD. Contributions to cryptography are made
under the terms of *both* these licenses.
The code used in the OS random engine is derived from CPython, and is licensed
under the terms of the PSF License Agreement.
./LICENSE.APACHE
Apache License
./LICENSE.BSD
Copyright (c) Individual contributors.
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
3. Neither the name of PyCA Cryptography nor the names of its contributors
may be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
./LICENSE.PSF
1. This LICENSE AGREEMENT is between the Python Software Foundation ("PSF"), and
the Individual or Organization ("Licensee") accessing and otherwise using Python
2.7.12 software in source or binary form and its associated documentation.
2. Subject to the terms and conditions of this License Agreement, PSF hereby
grants Licensee a nonexclusive, royalty-free, world-wide license to reproduce,
analyze, test, perform and/or display publicly, prepare derivative works,
distribute, and otherwise use Python 2.7.12 alone or in any derivative
version, provided, however, that PSF's License Agreement and PSF's notice of
copyright, i.e., "Copyright © 2001-2016 Python Software Foundation; All Rights
Reserved" are retained in Python 2.7.12 alone or in any derivative version
prepared by Licensee.
3. In the event Licensee prepares a derivative work that is based on or
incorporates Python 2.7.12 or any part thereof, and wants to make the
derivative work available to others as provided herein, then Licensee hereby
agrees to include in any such work a brief summary of the changes made to Python
2.7.12.
4. PSF is making Python 2.7.12 available to Licensee on an "AS IS" basis.
PSF MAKES NO REPRESENTATIONS OR WARRANTIES, EXPRESS OR IMPLIED. BY WAY OF
EXAMPLE, BUT NOT LIMITATION, PSF MAKES NO AND DISCLAIMS ANY REPRESENTATION OR
WARRANTY OF MERCHANTABILITY OR FITNESS FOR ANY PARTICULAR PURPOSE OR THAT THE
USE OF PYTHON 2.7.12 WILL NOT INFRINGE ANY THIRD PARTY RIGHTS.
5. PSF SHALL NOT BE LIABLE TO LICENSEE OR ANY OTHER USERS OF PYTHON 2.7.12
FOR ANY INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OR LOSS AS A RESULT OF
MODIFYING, DISTRIBUTING, OR OTHERWISE USING PYTHON 2.7.12, OR ANY DERIVATIVE
THEREOF, EVEN IF ADVISED OF THE POSSIBILITY THEREOF.
6. This License Agreement will automatically terminate upon a material breach of
its terms and conditions.
7. Nothing in this License Agreement shall be deemed to create any relationship
of agency, partnership, or joint venture between PSF and Licensee. This License
Agreement does not grant permission to use PSF trademarks or trade name in a
trademark sense to endorse or promote products or services of Licensee, or any
third party.
8. By copying, installing or otherwise using Python 2.7.12, Licensee agrees
to be bound by the terms and conditions of this License Agreement.
./vectors/LICENSE
./vectors/LICENSE.APACHE
Apache 2.0
./vectors/LICENSE.BSD
BSD 3-Clause
Dependency: :idna
Copyright: Kim Davies
License: BSD 3-Clause
./LICENSE.md
BSD 3-Clause License
Copyright (c) 2013-2021, Kim Davies
Dependency: :ntlm-auth
Copyright: Jordan Borean
License: MIT
./LICENSE
MIT License
Copyright (c) 2018 Jordan Borean, Red Hat
Dependency: :pycparser
Copyright: Eli Bendersky
./LICENSE
pycparser -- A C parser in Python
Copyright (c) 2008-2020, Eli Bendersky
Redistribution and use in source and binary forms, with or without modification,
* Redistributions of source code must retain the above copyright notice, this
* Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
* Neither the name of Eli Bendersky nor the names of its contributors may
be used to endorse or promote products derived from this software without
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
./pycparser/ply/LICENSE
PLY (Python Lex-Yacc) Version 3.10
Copyright (C) 2001-2017
David M. Beazley (Dabeaz LLC)
met:
* Neither the name of the David Beazley or Dabeaz LLC may be used to
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
More information about PLY can be obtained on the PLY webpage at:
http://www.dabeaz.com/ply
Dependency: :requests
License: Apache 2.0
./LICENSE
Apache License
./docs/_themes/LICENSE
Modifications:
Copyright (c) 2011 Kenneth Reitz.
Original Project:
Copyright (c) 2010 by Armin Ronacher.
Some rights reserved.
Redistribution and use in source and binary forms of the theme, with or
without modification, are permitted provided that the following conditions
are met:
notice, this list of conditions and the following disclaimer.
copyright notice, this list of conditions and the following
disclaimer in the documentation and/or other materials provided
* The names of the contributors may not be used to endorse or
promote products derived from this software without specific
We kindly ask you to only use these themes in an unmodified manner just
for Flask and Flask-related products, not for unrelated projects. If you
like the visual style and want to use it for your own projects, please
consider making some larger changes to the themes (such as changing
font faces, sizes, colors or margins).
THIS THEME IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS THEME, EVEN IF ADVISED OF THE
./ext/LICENSE
Copyright 2019 Kenneth Reitz. All rights reserved.
./NOTICE
Requests
Dependency: :requests-ntlm
Copyright: Ben Toews
License: ISC License
./LICENSE
ISC License
Copyright (c) 2013 Ben Toews
Dependency: :six
Copyright: Benjamin Peterson
License: MIT
./LICENSE
Copyright (c) 2010-2020 Benjamin Peterson
Dependency: :urllib3
Copyright: Andrey Petrov
License: MIT
./LICENSE.txt
MIT License
Copyright (c) 2008-2020 Andrey Petrov and contributors (see CONTRIBUTORS.txt)
Dependency: :xmltodict
Copyright: Martin Blech
License: MIT
./LICENSE
Copyright (C) 2012 Martin Blech and individual contributors.
