Ruby Licenses
Ruby is copyrighted free software by Yukihiro Matsumoto <matz@netlab.jp>.
You can redistribute it and/or modify it under either the terms of the
2-clause BSDL:
Copyright (C) 1993-2013 Yukihiro Matsumoto. All rights reserved.
BSD 2-Clause License
Or the conditions below:
1. You may make and give away verbatim copies of the source form of the
software without restriction, provided that you duplicate all of the
original copyright notices and associated disclaimers.
2. You may modify your copy of the software in any way, provided that
you do at least ONE of the following:
a) place your modifications in the Public Domain or otherwise
make them Freely Available, such as by posting said
modifications to Usenet or an equivalent medium, or by allowing
the author to include your modifications in the software.
b) use the modified software only within your corporation or
organization.
c) give non-standard binaries non-standard names, with
instructions on where to get the original software distribution.
d) make other distribution arrangements with the author.
3. You may distribute the software in object code or binary form,
provided that you do at least ONE of the following:
a) distribute the binaries and library files of the software,
together with instructions (in the manual page or equivalent)
on where to get the original distribution.
b) accompany the distribution with the machine-readable source of
the software.
4. You may modify and include the part of the software into any other
software (possibly commercial). But some files in the distribution
are not written by the author, so that they are not under these terms.
For the list of those files and their copying conditions, see below.
5. The scripts and library files supplied as input to or produced as
output from the software do not automatically fall under the
copyright of the software, but belong to whomever generated them,
and may be sold commercially, and may be aggregated with this
software.
6. THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE.
LEGAL NOTICE INFORMATION
All the files in this distribution are covered under either the Ruby's
license (see the file COPYING) or public-domain except some files
mentioned below.
[addr2line.c]
A part of this file is from FreeBSD.
Copyright (c) 1986, 1988, 1991, 1993
The Regents of the University of California. All rights reserved.
(c) UNIX System Laboratories, Inc.
All or some portions of this file are derived from material licensed
to the University of California by American Telephone and Telegraph
Co. or Unix System Laboratories, Inc. and are reproduced herein with
the permission of UNIX System Laboratories, Inc.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
4. Neither the name of the University nor the names of its contributors
may be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
SUCH DAMAGE.
@(#)subr_prf.c 8.3 (Berkeley) 1/21/94
[ccan/build_assert/build_assert.h]
[ccan/check_type/check_type.h]
[ccan/container_of/container_of.h]
[ccan/str/str.h]
These files are licensed under the CC0.
https://creativecommons.org/choose/zero/
Creative Commons Legal Code
[ccan/list/list.h]
This file is licensed under the MIT License.
MIT License
[coroutine]
Unless otherwise specified, these files are licensed under the MIT License.
[include/ruby/onigmo.h]
[include/ruby/oniguruma.h]
[regcomp.c]
[regenc.c]
[regenc.h]
[regerror.c]
[regexec.c]
[regint.h]
[regparse.c]
[regparse.h]
[enc/ascii.c]
[enc/big5.c]
[enc/cp949.c]
[enc/emacs_mule.c]
[enc/encdb.c]
[enc/euc_jp.c]
[enc/euc_kr.c]
[enc/euc_tw.c]
[enc/gb18030.c]
[enc/gb2312.c]
[enc/gbk.c]
[enc/iso_8859_1.c]
[enc/iso_8859_10.c]
[enc/iso_8859_11.c]
[enc/iso_8859_13.c]
[enc/iso_8859_14.c]
[enc/iso_8859_15.c]
[enc/iso_8859_16.c]
[enc/iso_8859_2.c]
[enc/iso_8859_3.c]
[enc/iso_8859_4.c]
[enc/iso_8859_5.c]
[enc/iso_8859_6.c]
[enc/iso_8859_7.c]
[enc/iso_8859_8.c]
[enc/iso_8859_9.c]
[enc/koi8_r.c]
[enc/koi8_u.c]
[enc/shift_jis.c]
[enc/unicode.c]
[enc/us_ascii.c]
[enc/utf_16be.c]
[enc/utf_16le.c]
[enc/utf_32be.c]
[enc/utf_32le.c]
[enc/utf_8.c]
[enc/windows_1251.c]
[enc/windows_31j.c]
Onigmo (Oniguruma-mod) LICENSE
Copyright (c) 2002-2009 K.Kosako <sndgk393 AT ybb DOT ne DOT jp>
Copyright (c) 2011-2014 K.Takata <kentkt AT csc DOT jp>
Oniguruma LICENSE
* https://github.com/k-takata/Onigmo/
* https://github.com/kkos/oniguruma
* https://svnweb.freebsd.org/ports/head/devel/oniguruma/
When this software is partly used or it is distributed with Ruby,
this of Ruby follows the license of Ruby.
[enc/windows_1250.c]
[enc/windows_1252.c]
Copyright (c) 2006-2007 Byte <byte AT mail DOT kna DOT ru>
[enc/cesu_8.c]
[enc/windows_1253.c]
[enc/windows_1254.c]
[enc/windows_1257.c]
Copyright (c) 2002-2007 K.Kosako <sndgk393 AT ybb DOT ne DOT jp>
[enc/trans/GB/GB12345%UCS.src]
[enc/trans/GB/UCS%GB12345.src]
[enc/trans/GB/GB2312%UCS.src]
[enc/trans/GB/UCS%GB2312.src]
These files have this explanatory texts.
This mapping data was created from files provided by Unicode, Inc.
(The Unicode Consortium). The files were used to create a product supporting
Unicode, as explicitly permitted in the files' copyright notices.
Please note that Unicode, Inc. never made any claims as to fitness of these
files for any particular purpose, and has ceased to publish the files many
years ago.
[enc/trans/JIS/JISX0201-KANA%UCS.src]
[enc/trans/JIS/JISX0208\@1990%UCS.src]
[enc/trans/JIS/JISX0212%UCS.src]
[enc/trans/JIS/UCS%JISX0201-KANA.src]
[enc/trans/JIS/UCS%JISX0208@1990.src]
[enc/trans/JIS/UCS%JISX0212.src]
These files are copyrighted as the following.
© 2015 Unicode®, Inc.
For terms of use, see http://www.unicode.org/terms_of_use.html
[enc/trans/JIS/JISX0213-1%UCS@BMP.src]
[enc/trans/JIS/JISX0213-1%UCS@SIP.src]
[enc/trans/JIS/JISX0213-2%UCS@BMP.src]
[enc/trans/JIS/JISX0213-2%UCS@SIP.src]
Copyright (C) 2001 earthian@tama.or.jp, All Rights Reserved.
Copyright (C) 2001 I'O, All Rights Reserved.
Copyright (C) 2006 Project X0213, All Rights Reserved.
You can use, modify, distribute this table freely.
[enc/trans/JIS/UCS@BMP%JISX0213-1.src]
[enc/trans/JIS/UCS@BMP%JISX0213-2.src]
[enc/trans/JIS/UCS@SIP%JISX0213-1.src]
[enc/trans/JIS/UCS@SIP%JISX0213-2.src]
[enc/trans/ucm/glibc-BIG5-2.3.3.ucm]
[enc/trans/ucm/glibc-BIG5HKSCS-2.3.3.ucm]
Copyright (C) 2001-2005 International Business Machines
Corporation and others. All Rights Reserved.
[enc/trans/ucm/windows-950-2000.ucm]
[enc/trans/ucm/windows-950_hkscs-2001.ucm]
Copyright (C) 2001-2002 International Business Machines
[tool/lib/test/*]
[tool/lib/core_assertions.rb]
Some of methods on these files are based on MiniTest 4. MiniTest 4 is
distributed under the MIT License.
Copyright (c) Ryan Davis, seattle.rb
MIT License
[parse.c]
[parse.h]
These files are licensed under the GPL, but are incorporated into Ruby and
redistributed under the terms of the Ruby license, as permitted by the
exception to the GPL below.
Copyright (C) 1984, 1989-1990, 2000-2015, 2018 Free Software Foundation, Inc.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
As a special exception, you may create a larger work that contains
part or all of the Bison parser skeleton and distribute that work
under terms of your choice, so long as that work isn't itself a
parser generator using the skeleton or a modified version thereof
as a parser skeleton. Alternatively, if you modify or redistribute
the parser skeleton itself, you may (at your option) remove this
special exception, which will cause the skeleton and the resulting
Bison output files to be licensed under the GNU General Public
License without this special exception.
This special exception was added by the Free Software Foundation in
version 2.2 of Bison.
[missing/dtoa.c]
This file is under these licenses.
Copyright (c) 1991, 2000, 2001 by Lucent Technologies.
Permission to use, copy, modify, and distribute this software for any
purpose without fee is hereby granted, provided that this entire notice
is included in all copies of any software which is or includes a copy
or modification of this software and in all copies of the supporting
documentation for such software.
THIS SOFTWARE IS BEING PROVIDED "AS IS", WITHOUT ANY EXPRESS OR IMPLIED
WARRANTY. IN PARTICULAR, NEITHER THE AUTHOR NOR LUCENT MAKES ANY
REPRESENTATION OR WARRANTY OF ANY KIND CONCERNING THE MERCHANTABILITY
OF THIS SOFTWARE OR ITS FITNESS FOR ANY PARTICULAR PURPOSE.
Copyright (c) 2004-2008 David Schultz <das@FreeBSD.ORG>
[win32/win32.c]
[include/ruby/win32.h]
You can apply the Artistic License to these files. (or GPL,
alternatively)
Copyright (c) 1993 Intergraph Corporation
You may distribute under the terms of either the GNU General Public
License or the Artistic License, as specified in the perl README file.
Artistic License, Version 2.0
random.c:
This file contains the source code under the new-style BSD license.
[missing/mt19937.c]
This file is under the new-style BSD license.
A C-program for MT19937, with initialization improved 2002/2/10.
Coded by Takuji Nishimura and Makoto Matsumoto.
This is a faster version by taking Shawn Cokus's optimization,
Matthe Bellew's simplification, Isaku Wada's real version.
Before using, initialize the state by using init_genrand(seed)
or init_by_array(init_key, key_length).
Copyright (C) 1997 - 2002 Makoto Matsumoto and Takuji Nishimura,
BSD 3-Clause License
Any feedback is very welcome.
http://www.math.keio.ac.jp/matumoto/emt.html
email: matumoto@math.keio.ac.jp
The Wayback Machine url: http://web.archive.org/web/19990429082237/http://www.math.keio.ac.jp/matumoto/emt.html
[missing/procstat_vm.c]
Copyright (c) 2007 Robert N. M. Watson
$FreeBSD: head/usr.bin/procstat/procstat_vm.c 261780 2014-02-11 21:57:37Z jhb $
[vsnprintf.c]
This file is under the old-style BSD license.
Copyright (c) 1990, 1993
This code is derived from software contributed to Berkeley by
Chris Torek.
[st.c]
[strftime.c]
[include/ruby/st.h]
[missing/acosh.c]
[missing/alloca.c]
[missing/erf.c]
[missing/hypot.c]
[missing/lgamma_r.c]
[missing/memcmp.c]
[missing/memmove.c]
[missing/strchr.c]
[missing/strerror.c]
[missing/strstr.c]
[missing/tgamma.c]
[ext/date/date_strftime.c]
[ext/digest/sha1/sha1.c]
[ext/digest/sha1/sha1.h]
These files are all under public domain.
[missing/crypt.c]
Copyright (c) 1989, 1993
Tom Truscott.
[missing/setproctitle.c]
Copyright 2003 Damien Miller
Copyright (c) 1983, 1995-1997 Eric P. Allman
Copyright (c) 1988, 1993
[missing/strlcat.c]
[missing/strlcpy.c]
These files are under an ISC-style license.
Copyright (c) 1998, 2015 Todd C. Miller <Todd.Miller@courtesan.com>
purpose with or without fee is hereby granted, provided that the above
copyright notice and this permission notice appear in all copies.
THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
[missing/langinfo.c]
This file is from http://www.cl.cam.ac.uk/~mgk25/ucs/langinfo.c.
Ruby uses a modified version. The file contains the following
author/copyright notice:
Markus.Kuhn@cl.cam.ac.uk -- 2002-03-11
for any purpose and without fee is hereby granted. The author
disclaims all warranties with regard to this software.
[ext/digest/md5/md5.c]
[ext/digest/md5/md5.h]
These files are under the following license. Ruby uses modified
versions of them.
Copyright (C) 1999, 2000 Aladdin Enterprises. All rights reserved.
This software is provided 'as-is', without any express or implied
warranty. In no event will the authors be held liable for any damages
arising from the use of this software.
Permission is granted to anyone to use this software for any purpose,
including commercial applications, and to alter it and redistribute it
freely, subject to the following restrictions:
1. The origin of this software must not be misrepresented; you must not
claim that you wrote the original software. If you use this software
in a product, an acknowledgment in the product documentation would be
appreciated but is not required.
2. Altered source versions must be plainly marked as such, and must not be
misrepresented as being the original software.
3. This notice may not be removed or altered from any source distribution.
L. Peter Deutsch
ghost@aladdin.com
[ext/digest/rmd160/rmd160.c]
[ext/digest/rmd160/rmd160.h]
These files have the following copyright information, and by the
author we are allowed to use it under the new-style BSD license.
AUTHOR Antoon Bosselaers, ESAT-COSIC
(Arranged for libc by Todd C. Miller)
DATE 1 March 1996
Copyright (c) Katholieke Universiteit Leuven
1996, All Rights Reserved
[ext/digest/sha2/sha2.c]
[ext/digest/sha2/sha2.h]
These files are under the new-style BSD license.
Copyright 2000 Aaron D. Gifford. All rights reserved.
[ext/json/generator/generator.c]
The file contains the following copyright notice.
Copyright 2001-2004 Unicode, Inc.
Disclaimer
This source code is provided as is by Unicode, Inc. No claims are
made as to fitness for any particular purpose. No warranties of any
kind are expressed or implied. The recipient agrees to determine
applicability of information provided. If this file has been
purchased on magnetic or optical media from Unicode, Inc., the
sole remedy for any claim will be exchange of defective media
within 90 days of receipt.
Limitations on Rights to Redistribute This Code
Unicode, Inc. hereby grants the right to freely use the information
supplied in this file in the creation of products supporting the
Unicode Standard, and to make copies of this file in any form
for internal or external distribution as long as this notice
remains attached.
[ext/nkf/nkf-utf8/config.h]
[ext/nkf/nkf-utf8/nkf.c]
[ext/nkf/nkf-utf8/utf8tbl.c]
These files are under the following license. So to speak, it is
copyrighted semi-public-domain software.
Copyright (C) 1987 Fujitsu LTD. (Itaru ICHIKAWA)
Everyone is permitted to do anything on this program
including copying, modifying, improving,
as long as you don't try to pretend that you wrote it.
i.e., the above copyright notice has to appear in all copies.
Binary distribution requires original version messages.
You don't have to ask before copying, redistribution or publishing.
THE AUTHOR DISCLAIMS ALL WARRANTIES WITH REGARD TO THIS SOFTWARE.
[ext/psych]
[test/psych]
The files under these directories are under the following license, except for
ext/psych/yaml.
Copyright 2009 Aaron Patterson, et al.
MIT License
[ext/psych/yaml]
The files under this directory are under the following license.
Copyright (c) 2006 Kirill Simonov
MIT License
[ext/pty/pty.c]
C) Copyright 1998 by Akinori Ito.
This software may be redistributed freely for this purpose, in full
or in part, provided that this entire copyright notice is included
on any copies of this software and applications and derivations thereof.
This software is provided on an "as is" basis, without warranty of any
kind, either expressed or implied, as to any matter including, but not
limited to warranty of fitness of purpose, or merchantability, or
results obtained from use of this software.
[ext/socket/addrinfo.h]
[ext/socket/getaddrinfo.c]
[ext/socket/getnameinfo.c]
Copyright (C) 1995, 1996, 1997, 1998, and 1999 WIDE Project.
[ext/win32ole/win32ole.c]
You can apply the Artistic License to this file. (or GPL,
alternatively)
(c) 1995 Microsoft Corporation. All rights reserved.
Developed by ActiveWare Internet Corp., http://www.ActiveWare.com
Other modifications Copyright (c) 1997, 1998 by Gurusamy Sarathy
<gsar@umich.edu> and Jan Dubois <jan.dubois@ibm.net>
License or the Artistic License, as specified in the README file
of the Perl distribution.
The Wayback Machine url: http://web.archive.org/web/19970607104352/http://www.activeware.com:80/
[lib/rdoc/generator/template/darkfish/css/fonts.css]
This file is licensed under the SIL Open Font License.
[spec/mspec]
[spec/ruby]
The files under these directories are under the following license.
Copyright (c) 2008 Engine Yard, Inc. All rights reserved.
MIT License
[lib/rubygems.rb]
[lib/rubygems]
[test/rubygems]
RubyGems is under the following license.
RubyGems is copyrighted free software by Chad Fowler, Rich Kilmer, Jim
Weirich and others. You can redistribute it and/or modify it under
either the terms of the MIT license, or the conditions
below:
a. place your modifications in the Public Domain or otherwise
b. use the modified software only within your corporation or
organization.
c. give non-standard executables non-standard names, with
d. make other distribution arrangements with the author.
3. You may distribute the software in object code or executable
form, provided that you do at least ONE of the following:
a. distribute the executables and library files of the software,
b. accompany the distribution with the machine-readable source of
the software.
software.
PURPOSE.
[lib/bundler]
[lib/bundler.rb]
[spec/bundler]
Bundler is under the following license.
Portions copyright (c) 2010 Andre Arko
Portions copyright (c) 2009 Engine Yard
MIT License
[lib/bundler/vendor/thor]
Thor is under the following license.
Copyright (c) 2008 Yehuda Katz, Eric Hodel, et al.
MIT License
[lib/rubygems/resolver/molinillo]
[lib/bundler/vendor/molinillo]
molinillo is under the following license.
Copyright (c) 2014 Samuel E. Giddins segiddins@segiddins.me
MIT License
[lib/bundler/vendor/connection_pool]
connection_pool is under the following license.
Copyright (c) 2011 Mike Perham
MIT License
[lib/bundler/vendor/net-http-persistent]
net-http-persistent is under the following license.
Copyright (c) Eric Hodel, Aaron Patterson
MIT License
[lib/did_you_mean]
[lib/did_you_mean.rb]
[test/did_you_mean]
did_you_mean is under the following license.
Copyright (c) 2014-2016 Yuki Nishijima
MIT License
[lib/error_highlight]
[lib/error_highlight.rb]
[test/error_highlight]
error_highlight is under the following license.
Copyright (c) 2021 Yusuke Endoh
MIT License
[benchmark/so_ackermann.rb]
[benchmark/so_array.rb]
[benchmark/so_binary_trees.rb]
[benchmark/so_concatenate.rb]
[benchmark/so_count_words.yml]
[benchmark/so_exception.rb]
[benchmark/so_fannkuch.rb]
[benchmark/so_fasta.rb]
[benchmark/so_k_nucleotide.yml]
[benchmark/so_lists.rb]
[benchmark/so_mandelbrot.rb]
[benchmark/so_matrix.rb]
[benchmark/so_meteor_contest.rb]
[benchmark/so_nbody.rb]
[benchmark/so_nested_loop.rb]
[benchmark/so_nsieve.rb]
[benchmark/so_nsieve_bits.rb]
[benchmark/so_object.rb]
[benchmark/so_partial_sums.rb]
[benchmark/so_pidigits.rb]
[benchmark/so_random.rb]
[benchmark/so_reverse_complement.yml]
[benchmark/so_sieve.rb]
[benchmark/so_spectralnorm.rb]
These files are very old copy of then-called "The Great Computer Language
Shootout". LEGAL SITUATION OF THESE FILES ARE UNCLEAR because the original
site has been lost. Upstream diverged to delete several benchmarks listed
above.
== MIT License
MIT License
== Old-style BSD license
are met:
3. Neither the name of the University nor the names of its contributors
SUCH DAMAGE.
IMPORTANT NOTE
From ftp://ftp.cs.berkeley.edu/pub/4bsd/README.Impt.License.Change
paragraph 3 above is now null and void.
