Selenium IDE Licenses
NOTICE file:
Copyright 2011-2016 Software Freedom Conservancy
Copyright 2004-2011 Selenium committers
Copyright 2016-2017 SideeX committers
This software (SideeX 2) preserves several key features of Selenium IDE and provides a number of advanced improvements. The preserved source code is copyrighted by Software Freedom Conservancy (2011-2016) and Selenium committers (2004-2011). The extended part of source code is copyrighted by SideeX committers (2016-2017).
Copyrights found in Selenium IDE source files:
// Licensed to the Software Freedom Conservancy (SFC) under one
// or more contributor license agreements. See the NOTICE file
// distributed with this work for additional information
// regarding copyright ownership. The SFC licenses this file
// to you under the Apache License, Version 2.0 (the
// "License"); you may not use this file except in compliance
// with the License. You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing,
// software distributed under the License is distributed on an
// "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY
// KIND, either express or implied. See the License for the
// specific language governing permissions and limitations
// under the License.
// This script will copy over the package.json version over
// to the manifest.version
* Copyright 2017 SideeX committers
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
* Copyright 2005 Shinya Kasatani
* Copyright 2011 Software Freedom Conservancy
// dControlFlowCommandChecks.istributed with thControlFlowCommandChecks.is work for additional information
// regarding copyright ownership. The SFC licenses thControlFlowCommandChecks.is file
// "License"); you may not use thControlFlowCommandChecks.is file except in compliance
// software dControlFlowCommandChecks.istributed under the License ControlFlowCommandChecks.is dControlFlowCommandChecks.istributed on an
// "AS ControlFlowCommandChecks.is" BASControlFlowCommandChecks.is, WITHOUT WARRANTIES OR CONDITIONS OF ANY
// specific language governing permControlFlowCommandChecks.issions and limitations
Apache License
4th party dependencies:
The following are covered under MIT License (standard verbiage here):
MIT License
@babel/core 7.3.4
@babel/plugin-proposal-class-properties 7.3.4
@babel/plugin-proposal-decorators 7.3.0
@babel/plugin-transform-runtime 7.3.4
@babel/preset-env 7.3.4 Copyright (c)
For all of the above - Copyright (c) 2014-present Sebastian McKenzie and other contributors
@babel/preset-react 7.0.0 Copyright (c) 2014-2018 Sebastian McKenzie
autoprefixer 7.1.4 Copyright 2013 Andrey Sitnik <andrey@sitnik.ru>
babel-loader 8.0.5 Copyright (c) 2014-2016 Luís Couto <hello@luiscouto.pt>
closure-loader 0.6.0 Copyright (c) 2017 Steven Weingärtner
copy-webpack-plugin 4.0.1 Copyright (c) 2015 Len Boyette
css-loader 0.28.7 Copyright JS Foundation and other contributors
dom-testing-library 3.12.0 Copyright (c) 2017 Kent C. Dodds
exports-loader 0.6.4 Copyright JS Foundation and other contributors
extract-text-webpack-plugin 3.0.0 Copyright JS Foundation and other contributors
file-loader 0.11.2 Copyright JS Foundation and other contributors
html-webpack-plugin 2.30.1 Copyright (c) 2014 Charles Blaxland
imports-loader 0.7.1 Copyright JS Foundation and other contributors
jest-dom 1.3.1 Copyright (c) 2017 Kent C. Dodds
postcss-flexbugs-fixes 3.2.0 Copyright 2015 Luis Rudge <luis@luisrudge.net>
postcss-loader 2.0.6 Copyright 2017 Andrey Sitnik <andrey@sitnik.ru>
raw-loader 0.5.1 Copyright JS Foundation and other contributors
react-hot-loader 3.0.0-beta.7 Copyright (c) 2016 Dan Abramov
react-testing-library 3.1.4 Copyright (c) 2017 Kent C. Dodds
style-loader 0.18.2 Copyright JS Foundation and other contributors
uglifyjs-webpack-plugin 1.3.0 Copyright JS Foundation and other contributors
url-loader 0.5.9 Copyright JS Foundation and other contributors
webpack 3.5.6 Copyright JS Foundation and other contributors
webpack-dev-server 2.8.2 Copyright JS Foundation and other contributors
@medv/finder 1.1.1 Copyright (c) 2018 Anton Medvedev
classnames 2.2.5 Copyright (c) 2016 Jed Watson
js-beautify 1.7.5 Copyright (c) 2007-2017 Einar Lielmanis, Liam Newman, and contributors.
mobx 5.9.0 Copyright (c) 2015 Michel Weststrate
mobx-react 5.4.3 Copyright (c) 2015 Michel Weststrate
modifier-keys 1.2.1 Copyright (c) 2017 Applitools
rc-slider 8.4.0 Copyright (c) 2015-present Alipay.com, https://www.alipay.com/
react 16.0.0 Copyright (c) 2013-present, Facebook, Inc.
react-autocomplete 1.7.2 Copyright (c) 2015 Ryan Florence
react-dnd-html5-backend 2.5.4 Copyright (c) 2015 Dan Abramov
react-document-title 2.0.3 Copyright (c) 2014 Dan Abramov
react-dom 16.4.2 Copyright (c) 2013-present, Facebook, Inc.
react-dropzone 4.2.9 Copyright (c) 2014 Param Aggarwal
react-linkify 0.2.2 Copyright (c) 2015 Tasti Zakarie
react-markdown 3.1.3 Copyright (c) 2015 Espen Hovlandsdal
react-modal 3.2.1 Copyright (c) 2017 Ryan Florence
react-split-pane 0.1.71 Copyright (c) 2015 tomkp
react-syntax-highlighter 8.0.1 Copyright (c) 2017 Conor Hastings
react-tooltip 3.8.1 Copyright (c) 2015 Wang Zixiao
resolve-url 0.2.1 Copyright (c) 2013 Simon Lydell
scroll-into-view-if-needed: 2 Copyright (c) 2017 Stian Didriksen
string-natural-compare 2.0.2 Copyright (c) 2015-2016 Nathan Woltman
styled-components 2.1.2 Copyright (c) 2016 Glen Maddern and Maximilian Stoiber
unescape 1.0.1 Copyright (c) 2014, 2016-2017, Jon Schlinkert
uuid 3.1.0 Copyright (c) 2010-2016 Robert Kieffer and other contributors
xml-escape 1.1.0 Copyright (c) 2014 Michael Hernandez
xml-js 1.5.2 Copyright (c) 2016-2017 Yousuf Almarzooqi
The following are covered under Apache 2.0 License (standard verbiage above):
fuse.js 3.3.0
google-closure-library 20170521.0.0
react-contenteditable 2.0.5
project-name-generator 2.1.4 (no license info found)
prop-types 15.5.10
BSD License
For React software
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this
list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
* Neither the name Facebook nor the names of its contributors may be used to
endorse or promote products derived from this software without specific
prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
react-dnd: 5.0.0
BSD License
Copyright (c) 2015, Facebook, Inc. All rights reserved.
react-transition-group 2.2.1
BSD 3-Clause License
Copyright (c) 2016, React Community
Forked from React (https://github.com/facebook/react) Copyright 2013-present, Facebook, Inc.
ua-parser-js 0.7.17
Dual licensed under GPLv2 & MIT
Copyright © 2012-2016 Faisal Salman
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
webextension-polyfill 0.3.1
Mozilla Public License Version 2.0
Mozilla Public License, Version 2.0
