System Elements Related to Alternate Work Schedule
This table lists system elements that are related to an alternate work schedule:
| System Element Name | Description | Format | DU | DB | DA | OS | PA | OR | Comments |
SCHED DFx1 ALT |
Schedule define x |
Decimal |
X |
X |
X |
X |
X |
X |
Represents the alternate work schedule's x user defined field. The value of this system element could vary each day. |
SCHED HRS ALT |
Scheduled Hours Alternate |
Decimal |
X |
X |
X |
X |
X |
X |
Represents the overridden work schedule's x user defined field from the daily work schedule override of the alternate workday ID. The value of this system element could vary each day. |
SCHED HRS ALT OR |
Decimal |
X |
X |
X |
X |
X |
Represents the overridden scheduled work hours from the daily work schedule override of the alternate workday ID. The value of this system element could be different each day of the event. |
SCHED HRS ALT WK |
Sched Hours Alt s/o Overrides |
Decimal |
X |
X |
X |
X |
X |
X |
Represents the scheduled work hours from the alternate work schedule. The value of this system element could be different each day of the event. |
SCHED ID ALT |
Alternate Work Schedule |
Character |
X |
Represents the alternate work scheduled ID. The value of this system element could be different each day of the event. |
SCHED OVER ALT IND |
Schedule Alt. Over. Ind |
Character |
X |
X |
X |
X |
X |
This system element equals 'Y' (Yes), if the day of the event being processed has a daily work schedule override for the alternate work day ID, else the system element equals 'N' (No). The value of this system element is calculated each day absent and therefore could be different each day. Valid Values: Character 'Y' &'N' ('Y' = Yes/'N' = No). |
WORK DAY ID ALT |
Work day ID |
Character |
X |
X |
X |
X |
X |
X |
Represents the workday ID of the alternate work schedule. The value of this system element could be different each day of the event. |
