(JPN) Setting Grade Advance Criteria
Grade advance criteria includes the number of reviews and their respective weights and the number of eligibility points that is required. The system checks for workers who meet the criteria that you specify here and reports those who are eligible to advance from the grade. Each grade has criteria that must be met before workers are eligible to advance from this grade to the next higher grade.
Weighted and Non-Weighted Sample Results
The decision to use weighted or nonweighted reviews has an effect on the results. In the examples that follow:
A is the worker's results.
B1 and B2 are settings for weighted and nonweighted (simple average) methods, respectively.
C1 and C2 are the results of A used with B1 and B2, respectively.
A: Worker's Review Results
This table shows the worker's review results:
Review Final Review Band Code Review Points
Most recent
A
80
Previous
S
100
B1: Weighted Method
This table shows B1 results using the weighted method:
Review Review Weight
Most recent
60%
Previous
40%
B2: Nonweighted (Simple Average) Method
This table shows B2 results using the nonweighted simple average method:
No. of Reviews Review Weight
2
NA
C1: Result of Using Weighted Method: 48 + 40 = 88
This table shows C1 results using the weighted method:
Review Final Review Band Code Eligibility Points Review Weight (from B1) Result of Weighted Review
Most Recent
A
80
60%
80 * 0.6 = 48
Previous
S
100
40%
100 * 0.4 = 40
C2: Result of Using Nonweighted (Simple Average) Method: = (80 + 100) / 2 = 90
This table shows C2 results using the nonweighted simple average method:
Review Final Review Band Code Eligibility Points Result of Nonweighted Average Review
Most Recent
A
80
(80+100)/2 = 90
Previous
S
100
(80+100)/2 = 90
