Defining Work Restrictions and Modified Work Duties
To define work restrictions and modified work duties, use the Work Restrictions Table (WORK_RESTRICT_TBL) and the Modified Work Table (MODIFIED_WORK_TBL) components.
When employees return to work after an injury or illness and are not able to immediately return to their full job duties, you can track rehabilitation plans that are established for them by using the codes that you set up in these tables.
Pages Used to Define Work Restrictions and Duties
| Page Name | Definition Name | Usage |
Work Restrictions Table or Codes and Effective Dates |
WORK_RESTRICT_TBL |
Identify physical limitations or restrictions placed on individuals as a result of injuries or illnesses. |
Modified Work |
MODIFIED_WORK_TBL |
Identify changes and modifications to processes or methods of doing a job. |
