1.1 Understanding PeopleSoft Portal Solutions vs. the Interaction Hub Product
Oracle's PeopleSoft Portal Solutions consist of the Interaction Hub and Internal Controls Enforcer. The PeopleSoft Portal Solutions database can contain one or multiple PeopleSoft portals. For example, if you are using the EMPLOYEE portal and the SUPPLIER portal, you can install both of these portals on a single PeopleSoft Portal Solutions database.
The PeopleSoft Interaction Hub product consists of portal features, pagelets, and applications that extend the PeopleSoft PeopleTools portal technology. The PeopleSoft Interaction Hub product is only supported in the PeopleSoft Portal Solutions database.
See Also
PeopleSoft Portal Solutions: Using Portal Features
PeopleSoft Portal Solutions: Internal Controls Enforcer
