Entering Notes for an Analytic Model Definition's Parts
Use the notes bar to create notes for the analytic model definition or its parts. To create a note:
  1. Select Start, and then Programs, and then PeopleTools 8.5x, and then Application Designer to access PeopleSoft Application Designer.
  2. After signing in to the PeopleSoft Application Designer, in the part browser, select the analytic model definition or the part for which you want to create a note.
  3. Click the notes bar.
  4. Enter the note.
    You can also press the Enter key to create multiple paragraphs and click the Cancel Changes button to cancel the changes you made to the note.
  5. Click the Accept Changes button to accept the changes you made to the note.
