Example: Using Default Aggregation
This topic provides an example of how to create an analytic model that uses default aggregation.
Requirements for Analytic Model
The following table provides an example of a table named MainData, which you specified as the main record of a cube collection.
DEPT field Data Type: Number SOMEDATE field Data type: Date NUM_SALES field Data Type: Number PRICE_PER_UNIT field Data Type: Number
101
20040101
1
10
102
20040102
2
14
103
20040101
4
15
201
20040101
8
20
202
20040201
16
23
You want the analytic model to:
  • Calculate aggregates for the NUM_SALES field.
  • Save the aggregates for the NUM_SALES field.
  • Establish hierarchies for the DEPT and SOMEDATE dimensions.
  • Refrain from calculating aggregates for the PRICE_PER_UNIT field.
  • Save all aggregates for the DEPT dimension.
  • Refrain from saving aggregates for the SOMEDATE dimension.
Creating the Aggregates
To fulfill the requirements of the analytic model, perform these steps:
  1. Create these dimensions:
    • DEPARTMENT
    • DATE
  2. Create these data cubes:
    • SALES
    • PRICE_PER_UNIT
  3. Enable the Calculate Aggregates field for the SALES data cube, because you want to calculate aggregates for this data cube.
  4. Ensure that the Calculate Aggregates field is disabled for the PRICE_PER_UNIT data cube, because you do not want to calculate aggregates for this data cube.
  5. Create a cube collection called SALES.
  6. Select MainData as the main record for the SALES cube collection.
  7. Map the data cubes and dimensions within the SALES cube collection to fields in the main record.
    The following table provides the mappings.
    Data Cube or Dimension to Map Field in Main Record
    DEPARTMENT dimension
    DEPARTMENT field
    Data type: Number
    SOMEDATE dimension
    SOMEDATE field
    Data type: Date
    SALES data cube
    NUM_SALES field
    Data type: Number
    Data type: Number
  8. Select the AGGRDATE record as the aggregate record.
    The AGGRDATE database record currently contains no data. The following table describes the fields within the record.
    Field Name Data Type
    DEPARTMENT
    String
    TREE_DATE
    String
    NUM_SALES
    Number
    Notice that even though the DEPARTMENT and TREE_DATE fields are of the String data type, none of the main record's fields are of this same data type. The DEPARTMENT and TREE_DATE fields are of the String data type because the hierarchy's members display strings, not dates or numbers. The data types of the aggregate record's fields must match the data types and lengths of the hierarchy's aggregate members. However, the data types of the aggregate record's fields do not need to match the data types of the main record's fields.
    If you design a tree's nodes so that the fields of the nodes are of the same data type as the fields of the detail members, you can use the same data type for both the dimension's aggregate record fields and main record fields.
  9. Map dimensions and data cubes to fields in the aggregate record.
    The following table lists the mappings.
    Data Cube or Dimension to Map Field in Aggregate Record
    DEPARTMENT field
    SOMEDATE dimension
    TREE_DATE field
    SALES data cube
    NUM_SALES field
  10. Use PeopleSoft Tree manager to create two trees:
    In the two tables, italicized children represent detail values. Remember, Analytic Calculation Engine creates detail members out of the tree's detail values to establish a dimension's parent-child relationships (in a tree, detail values can serve as children and parents).
    • DEPT_TREE
      Parents Children
      (no parent root)
      GBL
      GBL
      US
      GBL
      LAT AM
      US
      101
      US
      102
      US
      103
      LAT AM
      201
      LAT AM
      202
    • DATE_TREE
      Parents Children
      (no parent root)
      CAL2004
      CAL2004
      JAN
      CAL2004
      FEB
      JAN
      20040101
      JAN
      20040102
      FEB
      20040201
  11. Consider these scenarios for default sum aggregation:
    • If you select to persist all aggregates of both dimensions on the Dimensions tab of the cube collection's properties, the following rows are persisted in the aggregate record.
      Italicized values are the actual persisted aggregate members. Zero (0) values in this table are not persisted. The Fully Qualified Member Name field is not a database value.
      Fully Qualified Member Name DEPARTMENT TREE_DATE NUM_SALES
      GBL
      CAL2004.JAN. 20040101
      GBL
      20040101
      13
      GBL
      CAL2004.JAN.20040102
      GBL
      20040102
      2
      GBL
      CAL2004.FEB.20040201
      GBL
      20040201
      16
      GBL.US
      CAL2004.JAN.20040101
      US
      20040101
      5
      GBL.US
      US
      20040102
      2
      GBL.US
      US
      20040201
      0
      GBL.LAT AM
      LAT AM
      20040101
      8
      GBL.LAT AM
      LAT AM
      20040102
      0
      GBL.LAT AM
      LAT AM
      20040201
      16
      GBL.US.101
      CAL2004
      101
      CAL2004
      1
      GBL.US.102
      CAL2004
      102
      CAL2004
      2
      GBL.US.103
      CAL2004
      103
      CAL2004
      4
      GBL LAT AM.201
      CAL2004
      201
      CAL2004
      8
      GBL LAT AM.202
      CAL2004
      202
      CAL2004
      16
      GBL.US.101
      CAL2004.JAN
      101
      JAN
      1
      GBL.US.102
      CAL2004.JAN
      102
      JAN
      2
      GBL.US.103
      CAL2004.JAN
      103
      JAN
      4
      GBL.LAT AM.201
      CAL2004.JAN
      201
      JAN
      8
      GBL.LAT AM.202
      CAL2004.JAN
      202
      JAN
      0
      GBL.US.101
      CAL2004.FEB
      101
      FEB
      0
      GBL.US.102
      CAL2004.FEB
      102
      FEB
      0
      GBL.US.103
      CAL2004.FEB
      103
      FEB
      0
      GBL. LAT AM.202
      CAL2004.FEB
      201
      FEB
      0
      GBL. LAT AM.203
      CAL2004.FEB
      202
      FEB
      16
      GBL
      CAL2004
      GBL
      CAL2004
      31
      GBL
      CAL2004.JAN
      GBL
      JAN
      15
      GBL
      CAL2004.FEB
      GBL
      FEB
      16
      GBL.US
      CAL2004
      US
      CAL2004
      7
      GBL.US
      CAL2004. JAN
      US
      JAN
      7
      GBL.US
      CAL2004.FEB
      US
      FEB
      0
      GBL.LAT AM
      CAL2004
      LAT AM
      CAL2004
      24
      GBL.LAT AM
      CAL2004.JAN
      LAT AM
      JAN
      8
      GBL. LAT AM
      CAL2004.FEB
      LAT AM
      FEB
      16
    • If you select to persist all aggregates of the DEPT_TREE dimension and to persist none of the aggregates of the DATE_TREE dimension on the Dimensions tab of the cube collection's properties, the following rows are persisted in the aggregate record.
      Italicized values are the actual persisted aggregate members. Zero (0) values in this table not persisted. The Fully Qualified Member Name field is not a database value.
      GBL
      GBL
      20040101
      13
      GBL
      GBL
      20040102
      2
      GBL
      GBL
      20040201
      16
      GBL.US
      US
      20040101
      5
      GBL.US
      US
      20040102
      2
      GBL.US
      US
      20040201
      0
      GBL.LAT AM
      LAT AM
      20040102
      8
      GBL.LAT AM
      LAT AM
      20040102
      0
      GBL.LAT AM
      20040201
      LAT AM
      20040201
      16
    • If you select to persist only the root aggregations of the DEPT_TREE dimension and to persist none of the aggregates of the DATE_TREE dimension on the Dimensions tab of the cube collection's properties, the following rows are persisted in the aggregate record.
      Italicized values are the actual persisted aggregate members. The Fully Qualified Member Name field is not a database value.
      GBL
      GBL
      20040101
      13
      GBL
      20040102
      GBL
      20040102
      2
      GBL
      20040201
      GBL
      20040201
      16
