Opening an Analytic Model Definition
To open an analytic model definition:
  1. Select Start, and then Programs, and then PeopleTools 8.5x, and then Application Designer to access PeopleSoft Application Designer.
  2. Select File, and then Open after signing in to the PeopleSoft Application Designer.
    The Open Definition dialog box appears.
  3. Select the Analytic Model option in the Definition drop-down list box.
  4. Provide selection criteria.
    Enter an analytic model definition name or description (or the beginning characters of either), or select a project.
  5. Click the Open button or press Enter to display analytic model definitions matching the selection criteria that you entered.
    To clear the current selection criteria and start over, click the New Search button. To change how the search list appears, perform one of these actions:
    • Click the List button to view only the names of the analytic model definitions.
    • Click the Details button to view the names and descriptions.
      By default, both the names and descriptions appear in the search list.
  6. Double-click the analytic model definition that you want to open in the definition workspace, or highlight the analytic model definition and click the Open button.
    You can also press Shift+Left Click to select more than one definition to open in a single action, or right-click to view a pop-up menu from which you can open, print, rename, or delete the selected analytic model definition.
