PeopleSoft Application Designer Window Components for Creating Analytic Model Definitions
Navigation:
Start, and then Programs, and then PeopleTools 8.5x, and then Application Designer
This is an example of PeopleSoft Application Designer interface that is used for creating analytic model definitions.
PeopleSoft Application Designer interface for creating analytic model definitions
Term Definition
Menu Bar
Provides access to commands and features that you use to create analytic model definitions.
See the Menu Bar section below.
Tool Bar
Contains buttons that you use to perform common commands and edit the parts of an analytic model definition.
Formula Bar
Contains buttons that you use to define formulas for data cubes and user functions.
Rule Bar
Displays the rules for data cubes and user functions.
Note: The type of information that appears in the rule bar depends on the part that is currently selected.
Part Browser
Contains hierarchies that you use to view, organize, and edit an analytic model definition's parts.
See the Part Browser section below.
Part Property Editor
Contains dialog boxes that you use to edit the parts of an analytic model definition.
Notes Bar
Enables you to enter notes about the different parts of the analytic model definition.
Output Window
Contains the output text from PeopleSoft Application Designer operations, such as Build (SQL Create and Alter), Find Definition References, Upgrade, Results, Validate, and PeopleCode Log.
Status Bar
Contains descriptions of buttons and menu commands.
