Setting Column Properties for Analytic Grids
After you insert the page control or field into your grid, you can set the properties for that field as you would set properties for any other page control. Access the field properties by double-clicking the column heading. This properties dialog box behaves much as it does for ordinary grids.
See Application Designer Developer’s Guide: Setting Page Field Properties for Controls.
Settings that you select in the properties dialog, which comes up when you click an individual column in the analytic grid, override the settings that you select in the Analytic Grid Properties dialog box.
In addition, related display fields and related edit fields behave the same for analytic grids as they do for ordinary grids.
See Application Designer Developer’s Guide: Creating Display Control and Related Fields.
